JapCarForum General Discussions The JCF Lounge Electric turbos - why so long?
27-11-2019, 03:32 PM
Given that a turbo is essentially just a turbine, why has the idea of electrical assistance taken so long? Is it horrendously complicated to actually make it work?
27-11-2019, 03:32 PM #1
27-11-2019, 03:37 PM
An electric turbo is not a turbo at all, but a supercharger. You can get electric superchargers on ebay, they are rubbish and not worth bothering with!
27-11-2019, 03:37 PM #2
27-11-2019, 03:39 PM
BMW own the patent on the electric turbo...........
http://www.f30post.com/forums/showthread.php?t=597327
The Ebay ones are fans and are incapably of COMPRESSING air at anywhere near the pressure to make a difference.
Edited 08-01-2012, 07:26 PM by FirebirdPhil.
27-11-2019, 03:39 PM #3
Nah, there are now manufacturers (BMW I think?) using electric motors to pre-spin the turbos up for efficency and to remove lag. I'm sure I read that somewhere.
Edit: Bah, Phil beat me to it!
Edited 08-01-2012, 07:26 PM by toxo.
27-11-2019, 03:39 PM #4
27-11-2019, 03:56 PM
Yep not talking about the lame electric superchargers, more to do with this one that BMW is working on which will apparently be on the mental diesel soon to be released and also potentially the next M3.
BMWs version looks horrendously complicated but that's because it looks to be doing some extra clever stuff to make it really fuel efficient - but still begs the question of why no one has bothered with the basic concept before?
27-11-2019, 03:56 PM #5
27-11-2019, 04:39 PM
Marsdendean Unsure. How would it work, just go from a preset rev range and force a load of air in like a charger??
If you read the link Phil provided, they use a motor to pre-spin the turbo when the engine's not under load, so it's always spun up ready to function as a turbo, thus eliminating lag. A bit like anti-lag but using a motor instead of heavily retarding the ignition. The turbo is still a turbo, i.e. still powered by exhaust gas, it just won't slow down between gear changes etc.
Marsdendean And i doubt the M3 will be a diesel, because if it is, its the end of "propper" motoring. I like oil burners but not in sport cars, softtops or hardtops or high preformance cars . . .
Where does it say that it will be? They are making a new performance diesel as well as the new M3.
27-11-2019, 04:39 PM #6
27-11-2019, 04:43 PM
Marsdendean ^^ Sorry didnt read the link. Won't that cause the turbo to give up quicker, and is it just the retarded engine timing that kills turbo when using anti lag ?
Antilag kills turbos because the retarded ignition timing means fuel doesn't ignite in the combustion chamber, instead it makes its way through onto the exhaust turbine of the turbo and ignites there due to heat. So basically the turbo gets set on fire, which is what shortens its lifespan.
27-11-2019, 04:43 PM #7
27-11-2019, 06:48 PM
I have read about the BMW electric anti lag system, but as others have said that is only to prepare the turbo and not to generate any boost. If a motor does somehow generate boost and not the exhaust gas flow, then it would be an electric supercharger!
27-11-2019, 06:48 PM #8
28-11-2019, 04:47 AM
Wouldn't it be easier to have a gas compressor attached to the engine somewhere that can just periodically jet out a chunk of air and get the turbine spinning sooner? Could just refill once its on full boost then.
28-11-2019, 04:47 AM #9
28-11-2019, 05:47 AM
No because the turbo needs the heat from the exhaust and the gas to spin at the speeds required to compress the air. The heat is just as important as the exhaust flow.
Edited 09-01-2012, 09:33 AM by FirebirdPhil.
28-11-2019, 05:47 AM #10
Views 730
26-06-2021, 03:58 PM
Views 1,610
07-04-2021, 10:27 AM
Last Post by Fd3ste
Replies 22
Views 2,479
07-07-2020, 10:33 AM
Views 1,589
29-10-2019, 01:44 PM
Last Post by mr2tubbyben
Views 1,176
08-09-2019, 01:21 PM
Last Post by Phil01
Views 842
12-11-2018, 01:37 PM
Views 1,102
04-05-2018, 02:07 PM
Last Post by fluff
Views 650
19-03-2018, 04:02 AM
Views 2,076
16-06-2017, 03:05 AM
