JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Best battery for Lexus IS200?
Pages (3): 1 2 3 Next
13-12-2018, 11:37 AM
I have been making do with my dying battery, regularly jump starting the car and removing the battery to charge it a few times a week! But it now won't hold enough charge to start the engine after more than 5 or 6 hours parked up (though will do after a 15 minute charge!) I think it is time to give it up and replace it!
I know that the OEM Lexus battery is pretty good. But was thinking of something with a few more amps, as I plan to install various electric goodies which will add load to the system, and I sometimes don't drive the car for a week or more, so every little helps!
Rabster had an uprated one of some description IIRC, I don't mind making some modifications to the battery tray to fit it, but don't want to go quite as serious as Stav! Does anyone have an recommendations?
13-12-2018, 11:37 AM #1
13-12-2018, 12:39 PM
varta e44 is a very good battery mate, tis whats in the show piece 200, im using it in my car and cant fault it.
13-12-2018, 12:39 PM #2
MrGash
13-12-2018, 01:25 PM
im not too sure if they make them for the is200 but ive recently bought a bosch battery, not sure what its called, s4 or something got a silver lable with 4 stars, its good and strong, i watch dvds in mine for over an hour and the car still start easierly.
this is mine i just got:
[Image: 382893_2366363394295_1106723117_32052422...0639_n.jpg]
MrGash
13-12-2018, 01:25 PM #3
13-12-2018, 01:43 PM
whats the rating on that bosch 44Ah? the varta is 77Ah and has 780A on cold crank and has 5 year gaurantee
13-12-2018, 01:43 PM #4
13-12-2018, 01:44 PM
MrGash im not too sure if they make them for the is200 but ive recently bought a bosch battery, not sure what its called, s4 or something got a silver lable with 4 stars, its good and strong, i watch dvds in mine for over an hour and the car still start easierly.
I 2nd everything he said, I've got one of these in my car. It's a Bosch Silver Series/Silver Top. S means Silver, 4 means 4 year warranty. Completely sealed so you never have to top it up. Smile And has more CCA than the standard battery too. Didn't miss a beat through last years -20 winter!
Edited 24-01-2012, 11:19 PM by sprinter2012.
13-12-2018, 01:44 PM #5
MrGash
13-12-2018, 01:50 PM
think its 44ah 330A but not too sure, thing is how much does that battery cost? i paid £52 for mine
MrGash
13-12-2018, 01:50 PM #6
13-12-2018, 01:53 PM
its 80ish quid for the varta mate
13-12-2018, 01:53 PM #7
MrGash
13-12-2018, 01:58 PM
Thats alot of money for a battery. But i guess if your gonna be running alot of extras on it then it might be worth it, but the bosch one i bout is amazing power for money. Like i said i watch dvds for hours in mine and it doesnt affect it at all
MrGash
13-12-2018, 01:58 PM #8
That is the one I had in mind Dino! I wandered if there should be an alternative I should be looking for?
I will probably order THIS ONE.
As you say Dean, 780 CCA and 77AH. I don't think you can beat it for the money, just want to be sure I'm getting the best I can. Always liked Optimas, but I'm looking for under £100, and most of those are £200+!
Has anyone fitted one of these in an IS200 battery tray? (Rather than an IS300, which is different.) I understand some modding may be required, but do not know how much! The battery is nearly 5cm longer than the one in there at the mo, I will try to measure the tray and gap tomorrow, but I'm sure someone will have done it before!
13-12-2018, 01:58 PM #9
13-12-2018, 01:59 PM
Specs for the IS200 version are 70Ah, 630CCA.
And only £55+VAT! Bargain.
13-12-2018, 01:59 PM #10
Views 412
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 913
06-11-2022, 01:49 AM
Views 3,043
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,592
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 359
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
