JapCarForum Cars, Cars, Cars! General Car Maintenance headlights help
headlights help
headlights help
Biglee 22
25-12-2018, 02:43 AM
HELP!!!! morning guys and girls got woke up at 5:30 this morning to my clifford going off,went down to find the dip beam lights was on very dim disconnected the battery as only going to bed a couple of hours before a little bit tipsy lol thought i would sort it out later, went down just a min ago put a new battery on and as soon as popped it on the headlight control relay started buzzing like mad and the dip beam lights came on i changed the sensors on the dash but still buzzing like mad any ideas would be cool thanks guys
cheers lee
Biglee 22
25-12-2018, 02:43 AM #1
cheers lee
25-12-2018, 02:46 AM
could be water in the drivers fuse box, have you had a new windscreen ?
25-12-2018, 02:46 AM #2
Biglee 22
25-12-2018, 02:50 AM
hello mate no still the same screen will pop the covers off in a bit to see if there is any water there
Biglee 22
25-12-2018, 02:50 AM #3
25-12-2018, 02:56 AM
the other thing is the connector located under the plastic trim below the windscreen in the engine bay when my lights did this i found that connector had condensation/water once dried and taped up problem went away.....
25-12-2018, 02:56 AM #4
Biglee 22
25-12-2018, 03:00 AM
thanks rabster your a star just wiring my sky again so will check that later will let you know how i get on cheers mate
lee
Biglee 22
25-12-2018, 03:00 AM #5
lee
Biglee 22
28-12-2018, 10:03 AM
rabster your a diamond all sorted mate thanks again
lee
Biglee 22
28-12-2018, 10:03 AM #6
lee
28-12-2018, 10:33 AM
result which was it ?
28-12-2018, 10:33 AM #7
Biglee 22
28-12-2018, 02:18 PM
the connector under the stuttle panel mate one of the wires was frayed a bit taped it up good as new thanks again mate i owe you one :thumbup1:
lee
Biglee 22
28-12-2018, 02:18 PM #8
lee
Almost Finished
29-12-2018, 04:00 AM
Rabster is magic at car electrics . Glad you got it sorted .
Almost Finished
29-12-2018, 04:00 AM #9
29-12-2018, 04:21 AM
Glad to see it got sorted Rabster is great at these things and is always there to lend a hand
29-12-2018, 04:21 AM #10
Views 543
10-12-2020, 10:18 AM
Replies 68
Views 4,625
25-06-2017, 09:04 AM
