JapCarForum Cars, Cars, Cars! Project Cars My Subaru WRX
My Subaru WRX
My Subaru WRX
Pages (19): Previous 18 9 10 11 1219 Next
russelllinn
11-01-2017, 10:23 AM
#91
Thanks Asi Smile
steviewevie Cool. Is the over-fuelling the reason why the power drops off after 6200rpm ?
I had no idea what a Dawes device was, so I Googled it. So it's basically a manual boost controller ?
I think it probably is the reason as I would have expected it to hold for a bit longer really and yes the dawes device is basically a manual boost controller, I am going to be taking it off when the next stage takes place as I think it's a bit old skool now but it was mapped with it on so will wait til then!
Edited 22-02-2010, 08:24 PM by russelllinn.
russelllinn
11-01-2017, 10:23 AM #91
Thanks Asi Smile
russelllinn
14-01-2017, 01:03 PM
#92
Well originally I was going to refurb the standard brakes on my car as I got another set cheap, since then I have been thinking that they'll be adequate with the power increase but maybe not totally reliable so on this front I bought these Confusedmoke: you can see the difference in size to standard WRX 4 pots in the second pic!!
They run 330mm Discs Smile
[Image: Photo1069.jpg]
[Image: Photo1068.jpg]
Edited 25-02-2010, 10:44 PM by russelllinn.
russelllinn
14-01-2017, 01:03 PM #92
russelllinn
14-01-2017, 02:20 PM
#93
I am also working on the suspension setup as well so to start with I am uprating the drop links, on the standard setup the U shape rears are plastic and so flex a bit and the front are quite thin metal on a ball joint, I have purchased the below made out stress reliefed alloy by CDF racing and seem good quality from what I can make out :thumbup1:
[Image: Photo1070.jpg]
Edited 25-02-2010, 11:56 PM by russelllinn.
russelllinn
14-01-2017, 02:20 PM #93
russelllinn
14-01-2017, 02:25 PM
#94
I have also made a purchase from the same company of an anti-lift kit which stiffens the front and is designed to keep the front end from lifting as much on accelerating and as such keep more traction on the front wheels, we'll see eh :wink:
[Image: Photo1074.jpg]
russelllinn
14-01-2017, 02:25 PM #94
14-01-2017, 11:45 PM
#95
Mmm, those bits look nice. I see what you mean about the brakes being bigger :ohmy: :thumbup:
14-01-2017, 11:45 PM #95
15-01-2017, 01:33 AM
#96
They look tidy :thumbup1:
It amazes me how many manufacturers use plastic droplinks...
15-01-2017, 01:33 AM #96
15-01-2017, 01:44 AM
#97
See your moving in the right direction with all your goodies.:thumbup1:
15-01-2017, 01:44 AM #97
russelllinn
15-01-2017, 03:25 AM
#98
Cheers chaps Smile I am surprised too how they tend to use plastic on certain parts especially on a 'performance' cars!!
However I am pleased with the parts and it's all coming together nicely, just gotta put it all together at some point which maybe soon all going to plan, I am chatting with the garage at the moment to finalise bits and bobs :wink:
russelllinn
15-01-2017, 03:25 AM #98
russelllinn
22-01-2017, 06:34 AM
#99
I have sorted through the parts I need from what I originally bought and booked the car in for the 11th March at Chris Palmer Autos, Bristol who will have it (all going to plan for two days) one day for the fitting and setting up and the second for the mapping, they use Dave Row for all their mapping.
The following parts are being used for the upgrade -
TD05H 16G FE ported Turbo
STI Version 8 intercooler
Version 7 bonnet under tray to suit the larger cooler
STI Version 7 550 pink injectors
3 Port boost solenoid
Prodrive 255ltr fuel pump
RCM induction kit
All new gaskets, seals, bolts, necessary piping etc
At the same time they will be swapping the standard front calipers and discs to the Brembo calipers and discs, replacing the Rear Discs (grooved) and pads.
I am also adding Inlet Manifold spacers, which are about 10mm thick, there are two reasons for these; firstly they move the inlet manifold further from the heat source which reduces heat transfer from the heads to the manifold which in turn improves the torque curve. The mechanic has them on his rally car and has the dyno print before and after to show the differences.
As an aside they’ll be replacing the Rocker Cover Gaskets as they are weeping slighty so get them done before they leak
Big Grin Big Grin
russelllinn
22-01-2017, 06:34 AM #99
RCM induction kit
Big Grin Big Grin
22-01-2017, 07:47 AM
How long will they take to put on these up grades?
22-01-2017, 07:47 AM #100
 7 Guest(s)
 7 Guest(s)
Replies 57
Views 3,731
16-02-2024, 09:45 PM
Views 1,162
05-01-2023, 01:56 PM
Last Post by Jimbob-T-Lex
Views 2,130
20-06-2021, 04:50 AM
Views 1,097
21-02-2020, 12:58 PM
Last Post by jura
Views 2,782
19-05-2019, 07:53 AM
Last Post by Shaun TDI
Replies 22
Views 2,003
30-09-2018, 05:11 AM
Last Post by scooby 887
