JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! DIY custom supercharger parts list
Pages (21): Previous 19 10 11 12 1321 Next
Wayne
09-03-2023, 04:29 AM
That ain't overly bad. More then I'd ideally like to pay, but looks better then a flat piece with a pipe sticking out of it. Do you mind if I take your drawing and see what I can get em made up for? I'm going to see a man about em in the next few days.
Wayne
09-03-2023, 04:29 AM #101
P.Lindblom
09-03-2023, 05:12 AM
Wayne That ain't overly bad. More then I'd ideally like to pay, but looks better then a flat piece with a pipe sticking out of it. Do you mind if I take your drawing and see what I can get em made up for? I'm going to see a man about em in the next few days.
Go ahead, mate. Let me know if you need more dimensions.
The inlet would pretty much be a flat flange with a pipe, partly because you'd have to cast it to make it the same shape as the hole in the supercharger and partly because I'm pretty sure it wouldn't make a difference. I'm not sure the cone on the outlet would be necessary, but I'd rather have it and not need it than need it and not have it.
P.Lindblom
09-03-2023, 05:12 AM #102
Wayne
09-03-2023, 05:33 AM
Cheers, I'll let you know what he comes back with. I'll be ordering one of your black boxes later when I get back from work. I'll drop you a PM in a bit.
Wayne
09-03-2023, 05:33 AM #103
52
13-03-2023, 03:00 AM
Has anyone actually completed a conversion using 2" pipework?
Only reason for asking is that it looks small? Or as it's boosted does it not matter? It looks like a really tight fit in places so I'd rather use it if it isn't going to make a difference?
2 1/4" is available and that would also match the size of the intercooler outlets.
CrocodileHunter
13-03-2023, 03:00 AM #104
13-03-2023, 03:01 AM
U could use the 2 1/4 or the 2 there both fine
13-03-2023, 03:01 AM #105
13-03-2023, 03:11 AM
Will go for the 2 then
Cheers
CrocodileHunter
13-03-2023, 03:11 AM #106
Cheers
MJG94
18-03-2023, 04:52 AM
P.Lindblom I guess the demand for those superchargers kind of went up thanks to Pat's cradles Smile
Here's the pulley: http://www.ebay.co.uk/itm/281983477290
Thankyou!!!
MJG94
18-03-2023, 04:52 AM #107
Thankyou!!!
nomisnossnoj
02-04-2023, 01:14 PM
I think I just got a project for this Summer :p gonna check my economy and if that looks good I might just start collecting the parts!
nomisnossnoj
02-04-2023, 01:14 PM #108
captain
07-04-2023, 01:54 AM
For those with the mini cooper bypass valve, after a search I did about if there is a way to adjust the valve found out that in mini forums saying that from the factory the valve is not well adjusted and needs to readjust it because there is a leak and loose pressure. If you see through inside the valve with a light on the opposite side you will see light pass through which it should not. You have to unscrew the two bolts inside the pipe that holds the moving disk and try to adjust the disk not to see light from the opposite side you might need also to adjust the stop screw outside the pipe .I did it and get some more pressure and less noise!
captain
07-04-2023, 01:54 AM #109
52
07-04-2023, 12:28 PM
Ive just been out to the garage to check mine and it looks like it could do with a minor adjustment.
Thanks for the tip
CrocodileHunter
07-04-2023, 12:28 PM #110
Thanks for the tip
 23 Guest(s)
 23 Guest(s)
Views 1,602
21-03-2024, 04:36 PM
Views 2,006
07-04-2021, 04:23 AM
Last Post by daveo
Views 1,092
29-08-2020, 10:01 AM
Views 1,113
12-09-2019, 12:32 PM
Views 923
10-06-2019, 10:02 AM
