JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! DIY custom supercharger parts list
Pages (21): Previous 110 11 12 13 1421 Next
P.Lindblom
08-04-2023, 05:46 AM
A few people have asked me to provide them with the drawings for the inlets and outlets. The supercharger inlet is a bit awkward to dimension, since they are ususally made by flattening the pipe and making a matching hole in the flange, but I'll see what I can do.
Here are the other ones:
[Image: eaton_m62_supercharger_outlet_1.jpg]
[Image: mini_bypass_valve_inlet_1.jpg]
P.Lindblom
08-04-2023, 05:46 AM #111
Niliano
09-04-2023, 12:53 AM
Thought I would post this up:
http://www.ebay.co.uk/itm/Mercedes-Kompr...SwKfVXLbNP
a supercharger for sale at present for a is200 Smile
Niliano
09-04-2023, 12:53 AM #112
turbo 1
04-07-2023, 09:38 AM
hi i have trying to find a 150mm pulley in your parts list you put nissan nevaro do you have a part number as cant find one on ebay any would be great many thanks
turbo 1
04-07-2023, 09:38 AM #113
Wayne
04-07-2023, 10:37 AM
The nissan pulley is 130mm if I remember correctly, not 150mm. As far as I'm aware, you'd need to custom make a 150mm pulley.
Wayne
04-07-2023, 10:37 AM #114
turbo 1
04-07-2023, 03:25 PM
Ok thanks for the help
turbo 1
04-07-2023, 03:25 PM #115
05-07-2023, 02:08 AM
yeah as above the 150mm pulley would have to be made for it to fit
05-07-2023, 02:08 AM #116
turbo 1
05-07-2023, 03:36 AM
Hi again has anybody have part number for the 130mm pulley I most of the parts apart from pulley and cradle thanks
turbo 1
05-07-2023, 03:36 AM #117
Wayne
05-07-2023, 03:42 AM
Only part number I have is from the 138mm merc pulley. 6032050110, if its any help. You will need to have the holes redrilled. Pretty sure you need the holes doing on the Nissan pulley, I assume Pat could tell you more.
Sent from my Nexus 7 using Tapatalk
Wayne
05-07-2023, 03:42 AM #118
turbo 1
05-07-2023, 06:17 AM
Thanks I will check that out
turbo 1
05-07-2023, 06:17 AM #119
07-07-2023, 12:13 PM
Well just to give a heads up.
1 of the people that used this setup and design had his car dyno tested and the results are......
231.7bhp with the standard pulley.
WOW
sent from Admin HQ via tapatalk
07-07-2023, 12:13 PM #120
WOW
 14 Guest(s)
 14 Guest(s)
Views 1,602
21-03-2024, 04:36 PM
Views 2,006
07-04-2021, 04:23 AM
Last Post by daveo
Views 1,092
29-08-2020, 10:01 AM
Views 1,113
12-09-2019, 12:32 PM
Views 923
10-06-2019, 10:02 AM
