JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! DIY custom supercharger parts list
Pages (21): Previous 112 13 14 15 1621 Next
28-07-2024, 06:59 PM
How many people are needing these ???
28-07-2024, 06:59 PM #131
Wayne
29-07-2024, 03:48 AM
Yeah mine are 8mm and with my dodgy welding skills I even managed to warp it. Someone with a bit of skill and a decent welder may get away with 5mm. My fabber insisted on 8mm to minimise the warp.
Wayne
29-07-2024, 03:48 AM #132
29-07-2024, 11:14 AM
Speak to LEXUSPAT he has a proven track record and I think over 40 kits are now out there using his cradle design
29-07-2024, 11:14 AM #133
29-07-2024, 04:28 PM
Rabster Speak to LEXUSPAT he has a proven track record and I think over 40 kits are now out there using his cradle design
Oh well I was going to say I'd have a look at making these but think you should just ask LEXUSPAT now
29-07-2024, 04:28 PM #134
29-07-2024, 04:40 PM
Tbf although my fabricator is looking at doing them he hasn't taken any measurements or even had a good look at mine.
So if someone wants to look at these by all means but there is a lad on fb making them with built in bypass flange mounted to it
sent from Admin HQ via tapatalk
29-07-2024, 04:40 PM #135
DannyStock
03-08-2024, 03:41 PM
Well, no-one get their hopes up on these yet...
But CAD drawings have been made up and are looking good.
For other people that are running this s/c setup, what diameter pipe are you running on the outlet?
Drawings have been made up with a 2.5" outlet hole, I have asked for a 3" so then a reducer can be used down to 2" in a silly attempt for better flow/felxibility.
What size would be people like to see on them?
Cheers.
DannyStock
03-08-2024, 03:41 PM #136
Cheers.
03-08-2024, 03:54 PM
Most use 2.5 as most pipes are well priced at this size and with a 3 pipe below space is gonna be even tighter and is hell to work with.
Most go from 2.5 down to 2 and then back to 2.5 for inlet
03-08-2024, 03:54 PM #137
DannyStock
03-08-2024, 06:02 PM
I was planning on using 2" for the majority.
...Just using a 3" to 2" for the outlet manifold, trying to port match a little better.
If the majority are running with 2.5" outlet then i'll have a word with my man on CAD
DannyStock
03-08-2024, 06:02 PM #138
Wayne
03-08-2024, 09:12 PM
I found that if I wanted to use 2.5", I needed to angle the outlet and turn it slightly to the right. Otherwise it was never gonna fit. At first I followed Lindbloms design (found on page 11 on this thread, mine was 15mm longer), but the 90 coming off the outlet was touching the water pipes. Chopped a C section out, bent it over, now I have loads of room.
[Image: 1z2q4xz.jpg]
[Image: 29449x4.jpg]
Edited 15-09-2016, 12:58 AM by Wayne.
Wayne
03-08-2024, 09:12 PM #139
DannyStock
24-08-2024, 09:34 PM
Might be a bit out of place
The navara pulley is proving tricky to find, so I'm looking at the merc E300 item instead.
No-one has mentioned whether they have had any success with it on here?
Cheers.
DannyStock
24-08-2024, 09:34 PM #140
Cheers.
Views 2,872
21-03-2025, 10:24 PM
Views 3,101
07-04-2022, 10:12 AM
Last Post by daveo
Views 1,963
29-08-2021, 03:50 PM
Views 2,051
11-09-2020, 06:20 PM
Views 1,488
09-06-2020, 03:51 PM
