JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! DIY custom supercharger parts list
Pages (21): Previous 117 18 19 20 21 Next
DannyStock
12-09-2023, 02:37 AM
If yours wobbles a little bit thats good to know
I'm just not comfy with the thought of any eccentricity being loaded through the waterpump causing any premature wear...
The supercharger itself has a safe maximum of about 12/13k (iirc) continuous.
14/16K maximum for short bursts only.
But they're only effeceint up until about 10K, so theres no need to spin it massively.
All spinning it up faster does is get maximum boost earlier in the rev range of the engine.
DannyStock
12-09-2023, 02:37 AM #181
Wayne
12-09-2023, 02:47 AM
Yeah a slight wobble, nothing that I thought bad. I'm hoping once the belt is on it'll reduce it even more. I'll soon know once it starts shredding belts. There is a TTE pulley for sale on here, if you wanna spend a little more for peace of mind. I'm just gonna go with what I've got atm. I don't think I'll be having any problems.
Wayne
12-09-2023, 02:47 AM #182
DannyStock
12-09-2023, 04:52 AM
Well, belts are cheap enough at the end of the day.
I'm gonna reassemble the car, then spin it up with s/c in place see how it all looks.
All else fails I've got a plan B - 4PK1130 (after a little re-measuring) off the crank pulley
Should hook up at the sacrifice of aircon.
Thanks for the heads up, i'll have a quick search.
DannyStock
12-09-2023, 04:52 AM #183
Wayne
08-12-2023, 02:37 PM
Pat, did you redrill your tensioner? I fitted mine using the hole provided and it's pretty much touching the pulley.
Wayne
08-12-2023, 02:37 PM #184
09-12-2023, 12:23 PM
No mate, are u going through the hole in the middle and not the outer hole.
sent from Admin HQ via tapatalk
09-12-2023, 12:23 PM #185
Wayne
09-12-2023, 03:22 PM
[Image: 24d7c9f003ed4d4394fac291eb767c5e.png]
That hole, am I supposed to go through the hole in the middle then?
Wayne
09-12-2023, 03:22 PM #186
09-12-2023, 09:15 PM
Yes dude the long hole in the middle which allows u to adjust the tension as well by moving the tensioner left or right.
09-12-2023, 09:15 PM #187
Wayne
10-12-2023, 07:01 AM
Sound, I'll try that :p
Cheers Pat!
Wayne
10-12-2023, 07:01 AM #188
Cheers Pat!
26-12-2023, 04:21 AM
how did you get on wayne ?
26-12-2023, 04:21 AM #189
Wayne
26-12-2023, 07:01 AM
Rabster how did you get on wayne ?
Looks a lot better, but I spaced out my pulley so it's still throwing belts. Gonna whip em out and everything should be good then.
Wayne
26-12-2023, 07:01 AM #190
Views 1,489
21-03-2024, 04:36 PM
Views 1,898
07-04-2021, 04:23 AM
Last Post by daveo
Views 1,023
29-08-2020, 10:01 AM
Views 1,025
12-09-2019, 12:32 PM
Views 872
10-06-2019, 10:02 AM
