Sat nav unit screens
The best way to hold the screen in is a bracing bar across the back of the screen, don't try gluing it in place as the glue can become unstuck in the summer heat.
Get some pics of it working then :-p
Will tomorrow as don't have the connectors and still need to do a bit of wiring
Does anyone know what motor the unit uses to open and close the screen and where can I get one from?
It is but I'm not paying £200 for it,its only a simple motor so was wondering if maplins or someone did one,cos its either the board or motor gone in mine.
What's the best way to test the motor and the board separately?
Ok so tested the motor and that's fine which means the board if fecked,how can I re-wire it so it by passes the board so it opens and closes
Unless anyone has a spare board from butchering theirs
I'd be very surprised if there is anything wrong with the board itself...
Checklist:
So far I've powered the unit up as a whole and nothing,
Tested the motor seperately and that's working,
Just can't get the board out properly to see what's wrong
