JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help sourcing injectors. :)
09-01-2020, 09:54 AM
Yeah just as simple as cutting off old plugs and welding new ones on.
09-01-2020, 09:54 AM #11
Jon
09-01-2020, 10:03 AM
1ZZ are a straight swap (Dark Green Injectors from a 1.8 Celica/Avensis)
I got 7 off ebay for around £25 - second hand obviously, but they seem to be doing the job!
Jon
09-01-2020, 10:03 AM #12
09-01-2020, 10:21 AM
Jon 1ZZ are a straight swap (Dark Green Injectors from a 1.8 Celica/Avensis)
Well you learn something new everyday!
09-01-2020, 10:21 AM #13
Jon
09-01-2020, 10:34 AM
Sparkystav Well you learn something new everyday!
Correct me if im wrong, but I believe the standard injectors are 155cc/min, and the 1ZZ are around 250cc/min.
I also believe any injector with the 'Type F' connector should fit?
Jon
09-01-2020, 10:34 AM #14
ozzie b
11-01-2020, 12:16 AM
Thanks for the speedy reply guys, at least i have a bit more info on the part no's and whats required for fitting depending on which ones i go for. Thinking maybe with the rx8 yellow ones still atm as heard nothing but good things about them and should be about perfect for what im trying to achieve. :thumbup::thumbup:
ozzie b
11-01-2020, 12:16 AM #15
Views 572
11-04-2019, 03:04 AM
Last Post by LEX11S
