JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Max HP From 1GFE
Max HP From 1GFE
Max HP From 1GFE
28-08-2020, 12:24 PM
el_bandido You could hunt down the extremely rare 2.2 stroker kit, put some throttle bodies on it, get a load of head work done, balance it and up the rev limit to 8500 rpm and after £10,000 you'd probably see 200-210hp NA.
So you basically get a £10K Altezza. lol
I thought that 2.2 stroker kit you mentioned was for the Altezza anyway though? Or is there another one for the IS200?
28-08-2020, 12:24 PM #11
28-08-2020, 12:48 PM
Koss that's just boring what is needed is 6 turbos........................
Owen Developments did 4 a quad set up........
[Image: 5227_18020691525.jpg]
28-08-2020, 12:48 PM #12
28-08-2020, 02:11 PM
sprinter2012 So you basically get a £10K Altezza. lol
It's for the JDM MKIII 1g-gte supra engine but it will fit in the 1g-fe. I have only ever seen reference to its existence once on an Australian forum, it is extremely rare.
I think you'd get a bit more torque than a tez, but not by a considerable margin. t would be cheaper to put a v8 in the car and probably just as simple, as you'd need an aftermarket ecu for an ITB set up anyway.
Edit: Don't give me ideas Phil! A twin set up on each bank of a 1uz would be beastly.
Edited 10-10-2013, 12:02 AM by el_bandido.
28-08-2020, 02:11 PM #13
Danies200
30-08-2020, 02:55 AM
seems there is some parts available...
Will a catback from a altezza fit on a is200?Cause i see some
cheap catback systems on ebay.It looks the same to me,but
don't know if it fits.
Danies200
30-08-2020, 02:55 AM #14
30-08-2020, 04:08 AM
I think the backbox fits, but not the midpipe? So a catback system won't fit, I'm sure someone else should be able to confirm.
30-08-2020, 04:08 AM #15
30-08-2020, 05:40 AM
You could fit a unichip piggy back ecu that might help a bit
30-08-2020, 05:40 AM #16
30-08-2020, 08:51 AM
Depends which Altezza its for - the 6 cylinder is exactly the same, the 4 cylinder has a different mid pipe as Sprinter said.
30-08-2020, 08:51 AM #17
30-08-2020, 08:56 AM
Yeah, the AS200 has a 1GFE so the mechanics are the same as the IS200. The RS200 has the vvti 3SGE and on that engine the exhaust manifold is on the other side of the engine so the pipes don't match up
30-08-2020, 08:56 AM #18
Danies200
14-10-2020, 12:34 PM
since i put another aftermarket exhaust manifold and downpipe(megan racing),i have the p0141 faultcode.Is this something that normaly happen when changing exhaust system.Catback systeem is forward to come too.So is there a way to solve this?
Danies200
14-10-2020, 12:34 PM #19
Views 599
24-06-2020, 02:04 PM
Last Post by Lance79
Views 583
11-04-2019, 03:04 AM
Last Post by LEX11S
