JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! supercharger help.
supercharger help.
supercharger help.
daveo
06-02-2021, 02:11 PM
do you have a number for him by any chance?? what pully are you using , are you up and running
daveo
06-02-2021, 02:11 PM #11
deccie22
06-02-2021, 02:15 PM
no dont man but he does be on tezza world and toc-irl a good bit. using a w/p pulley off a slk merc. no not yet waiting on a few bits!
deccie22
06-02-2021, 02:15 PM #12
Lance79
14-02-2021, 12:17 PM
daveo can someone please help here explain a few things. the car is nearly ready for remapping. have supercharger mounted and hardpiped. i did not put anything on the bypass valve as i was thinking i could run without it.....can i run without it or am i better to install one. the cable off of the valve is broken but the spring is ok. do i have to replace this cord?? the car is drift spec .i am using a patrick black box. will this be ok with a 160mm pulley.?? any help greatly appreciated as im at a standstill at the moment.
You cannot remap an IS200 unless you have a standalone management system. The factory ECU will wipe any changes.
You don't need a bypass if you've a BOV. If you are going for a BOV you need a 1st generation HKS SSQV as they are the only ones that are adjustable which you need as the boost pressure of a supercharger is considerably lower than a turbo which they are more commonly used. You will need either a bypass or a BOV or else you'll get compressor surge and belt slip.
This is where i have my BOV mounted.
[Image: gallery_5086_212_264286.jpg]
Lance79
14-02-2021, 12:17 PM #13
beamstezza
14-02-2021, 02:07 PM
Any good quality bov will be adjustable and you can get bov for low boost setups as well.
beamstezza
14-02-2021, 02:07 PM #14
daveo
07-04-2021, 04:23 AM
Lance79 You cannot remap an IS200 unless you have a standalone management system. The factory ECU will wipe any changes.
so you have a bov and a bypass?? do you see my other thread........do you think this might sort my problem ??
daveo
07-04-2021, 04:23 AM #15
Replies 209
Views 26,479
06-04-2024, 05:29 PM
Last Post by lexus971
Views 1,735
21-03-2024, 04:36 PM
Views 1,177
29-08-2020, 10:01 AM
Views 1,186
12-09-2019, 12:32 PM
Views 976
10-06-2019, 10:02 AM
