JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! How to.... disassemble the TTE-charger on a Lexus IS200
09-07-2018, 02:03 PM
how much oil does the charger take?also weres the drain and fill plug??
09-07-2018, 02:03 PM #11
09-07-2018, 11:48 PM
Jeez you guys have got it easy with that charger. I wish my one was that simple! Sad
09-07-2018, 11:48 PM #12
10-07-2018, 02:15 PM
Stoney Great thread mate. Have some rep.
I've just taken mine apart and drained the oil. Need to clean it up a bit before reassembly, and prep it for painting. Can you recommend anything to clean it up with?
Also, how did you remove the one Allen bolt of the four that is very hard to access on the under side of the charger? I can't get anything into it, and so it is still attached!
do you know how much oil the charger takes?
10-07-2018, 02:15 PM #13
11-07-2018, 12:57 AM
ormi do you know how much oil the charger takes?
225ml, I think. I found the spec on google before, but now cannot! I did not measure what came out, but looked to be about that.
The drain hole is fairly obvious, on the underside of the charger, at the front, though may be slightly hidden behind the pulley.
EDIT: These pics show you....
About 225ml
abactus [Image: bc4mjkoovyewusm07.jpg]
The drain hole is on top in this pic (as the charger is upside down!) and has a blue dot on it.
abactus [Image: bc4lpwplnm4pzsk87.jpg]
Edited 22-08-2011, 10:38 AM by Stoney.
11-07-2018, 12:57 AM #14
About 225ml
11-07-2018, 10:18 AM
did you just use normal 75/90 gear oil?also when removing the drain plug did the oil just drain out?the only reason i ask is i just read it needs to be sucked out??
11-07-2018, 10:18 AM #15
11-07-2018, 10:20 AM
thought this might help people....
OEM Application Rotor Type
Size
Oil Fill (ml)
Oil Fill (fl oz)
Audi A6/S4 TVS
R1320
155
5.2
BMW / Mini 3-lobe
M45
145 + 40 (rear)
4.9 + 1.4 (rear)
Mercedes M271 3-lobe
M45
135
4.6
Mercedes EVO M111 3-lobe
M45
110
3.7
Mercedes Clutched 3-lobe
M62
110
3.7
Ford 3-lobe
M24
35
1.2
Ford Super Coupe 3-lobe
M90
240
8.1
Ford Shelby GT500 3-lobe
hybrid
H122
140
4.7
Ford Harley-Davidson
F150
3-lobe
M112
215
7.3
Ford Lightning 3-lobe
M112
215
7.3
Ford Cobra 3-lobe
M112
215
7.3
GM 3800 Series L67 3-lobe
M90
225
7.6
GM 3800 Series L32 3-lobe
M90
205
6.9
GM Cobalt SS LSJ 3-lobe
M62
100
3.4
GM Cadillac LC3 Northstar 3-lobe
M112
215
7.3
GM Cadillac LSA TVS
R1900
150
5.1
GM Corvette LS9 TVS
R2300
150
5.1
Jaguar AJ33 3-lobe
M112
215
7.3
Jaguar AJ43/44 3-lobe
M112
215
7.3
Jaguar AJ133 TVS
R1900
150
5.1
Nissan 3-lobe
M62
115
3.9
Volkswagen 3-lobe
M24
40
1.4
the above is from eton them selfs.....
im now confused you said 225ml if you look at the merc stats it says 110 ml and the nissan that uses the m62 uses 115ml????
Edited 22-08-2011, 07:58 PM by ormi.
11-07-2018, 10:20 AM #16
Size
Oil Fill (ml)
Oil Fill (fl oz)
Audi A6/S4 TVS
R1320
155
5.2
BMW / Mini 3-lobe
M45
145 + 40 (rear)
4.9 + 1.4 (rear)
M45
135
4.6
M45
110
3.7
M62
110
3.7
Ford 3-lobe
M24
35
1.2
M90
240
8.1
hybrid
H122
140
4.7
F150
3-lobe
M112
215
7.3
M112
215
7.3
Ford Cobra 3-lobe
M112
215
7.3
M90
225
7.6
M90
205
6.9
M62
100
3.4
M112
215
7.3
GM Cadillac LSA TVS
R1900
150
5.1
GM Corvette LS9 TVS
R2300
150
5.1
Jaguar AJ33 3-lobe
M112
215
7.3
M112
215
7.3
Jaguar AJ133 TVS
R1900
150
5.1
Nissan 3-lobe
M62
115
3.9
Volkswagen 3-lobe
M24
40
1.4
11-07-2018, 10:38 AM
i also just watched a video explaining that the chargers respond very well to polishing the triangle at the bottom of the charger(were the air is forced out)
11-07-2018, 10:38 AM #17
11-07-2018, 10:48 AM
ported m62 charger
http://youtu.be/GjSiSOdRI2Q
Edited 22-08-2011, 08:23 PM by ormi.
11-07-2018, 10:48 AM #18
ported m62 charger
11-07-2018, 03:48 PM
[Image: 4SuperchargerDrainPlug.jpg]
also found out its 200ml the charger takes
Edited 23-08-2011, 01:24 AM by ormi.
11-07-2018, 03:48 PM #19
rob
11-07-2018, 10:08 PM
i asked eaton and they told me 110ml.
the oil only needs to be sucked out if its on the merc as its mounted with the drain/fill plug on the top.
the oil is there as splash lubrication not immersion.
if any doubt drain out the current amount and measure but wont help if the oil has been changed in the past.
if its black then flush out the gear housing a few times.
rob
11-07-2018, 10:08 PM #20
Views 202
13-12-2022, 05:57 AM
Replies 46
Views 7,506
16-03-2022, 12:02 AM
Last Post by Emissary
Views 850
10-09-2021, 01:07 PM
Replies 25
Views 4,786
18-08-2019, 06:32 AM
Last Post by Johny47
Views 548
24-01-2019, 02:06 PM
Views 2,080
03-10-2018, 08:33 AM
Views 880
04-09-2018, 10:45 AM
Replies 41
Views 3,277
09-04-2018, 11:19 PM
Last Post by IanS200
Views 827
23-01-2018, 07:18 AM
Last Post by Jambo
