JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission IS200 Cam belt and water pump
Timbo
12-04-2017, 09:26 PM
I had the car done yesterday and not very happy they only changed the belt, thought a lexus dealer would know to do the full kit, now know the belts ok for another 60k at least but not the rest of it Angry
Timbo
12-04-2017, 09:26 PM #11
12-04-2017, 09:38 PM
So did they do the water pump when they done the belt?
So have you got to book back in for the ball joint?
12-04-2017, 09:38 PM #12
Timbo
12-04-2017, 09:44 PM
yes they did the water pump too and said the tensioner on the belt was fine so dont think it will go any time soon, ball joint was done last visit, just the rear discs and pads to do now Smile
Timbo
12-04-2017, 09:44 PM #13
12-04-2017, 10:36 PM
Yeah I think the dealer will not normally replace the tensioner. I guess they could say that people would complain if they always changed it, especially if it didn't look like it needed doing (i.e. it would cost more).
12-04-2017, 10:36 PM #14
captain
13-04-2017, 05:14 AM
Do you suggest to change tensioner and water pump with cam belt or it is not always necessary? Timpo your water pump had a problem or they changed it just in case...?
captain
13-04-2017, 05:14 AM #15
13-04-2017, 05:17 AM
It can be useful to change both. Firstly, if the tensioner is worn at all, then it will cause increased wear on your new cam belt.
As for the water pump, in order to replace this, you have to take all the belts off to do this part. So unless you can be sure your water pump will last till the next cam belt change, it makes it cheaper to change it at the same time as the cam belt. Of course, that depends on exactly how long your water pump is likely to last, and that can be difficult to tell ! You can always have a look at it and see if you can see any leaks. Mine looked fine to me, but when it came off I saw it had been leaking from underneath.
13-04-2017, 05:17 AM #16
captain
13-04-2017, 05:24 AM
Probably I am going to change them all.
Thanks stevie!
captain
13-04-2017, 05:24 AM #17
Thanks stevie!
Timbo
13-04-2017, 06:49 AM
They told me it was leaking visit before so needed doing and as its a common problem would be best to get done anyway methinks :thumbup1:
Timbo
13-04-2017, 06:49 AM #18
spikes
13-04-2017, 12:25 PM
did the whole lot on mine, but the guy who fitted kept the parts for me to see as pump wasnt leaking,tensioner and belt ok aswell,but it was overdue and i know its been done.:biggrin:
spikes
spikes
13-04-2017, 12:25 PM #19
spikes
Andy-R.
31-05-2017, 03:36 AM
Soz to re-start this thread but if the water pump has a leak is it a problem with the pump or just a worn out gasket? mines defo got a small leak but would rather just get the gasket done if that's all it'd need.
[Image: Lf9Nl.jpg]
Andy-R.
31-05-2017, 03:36 AM #20
[Image: Lf9Nl.jpg]
 3 Guest(s)
 3 Guest(s)
Views 245
09-01-2023, 02:08 PM
Last Post by Hoseer
Views 240
10-02-2022, 04:05 PM
Views 240
15-01-2022, 02:19 AM
Views 182
12-12-2021, 07:17 AM
Views 236
24-07-2021, 05:07 AM
Last Post by phaebo
Views 196
27-04-2021, 11:43 PM
Views 852
24-04-2021, 04:30 AM
Last Post by lexusdaydreaming
Replies 25
Views 774
18-05-2020, 11:50 AM
