JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security IS200 Aftermarket headunit HELP!
22-11-2017, 01:02 PM
lexluger Well so far i can only presume that the amp bypass lead i have is somehow the problem, i noticed there are some looped wires in the big white connector (amp side) of the bypass lead, does this sound right? Does anybody have a pic of their correct lead that i can cross referance with the one i have?
Cheers..
They'll be the ones linking the 2 rear speakers each side into one output each side.
22-11-2017, 01:02 PM #11
Cheers..
lexluger
22-11-2017, 01:10 PM
i cant get any pics up at the moment as it was getting dark & i have left the lead fitted. i had a look at bandits "how to" & the lead used in his pics is differant & has no loops in the connector?
lexluger
22-11-2017, 01:10 PM #12
22-11-2017, 01:14 PM
the loops may not be a problem the fact you are not getting any noise at all is suspicius on its own you could check the ouputs of the radio for voltage on the audio lines using a multimeter to ensure its giving an output...
22-11-2017, 01:14 PM #13
That one will prob just have two wires going into one connector at the other end
22-11-2017, 01:14 PM #14
lexluger
22-11-2017, 01:47 PM
Am i right in saying that the other smaller plug stays in the amp & the plug that used to go into the back of the standard HU is no longer needed? (car has no sat-nav ) I will have a fresh look at it another day. If all else fails i'll have to buy a differant bypass lead as it must be the problem seeing as nobody else has had any issues with what should just be plug & play,
Thanks for all you help..
lexluger
22-11-2017, 01:47 PM #15
22-11-2017, 02:34 PM
Disconnect both from amp to play it safe
22-11-2017, 02:34 PM #16
Views 619
30-09-2022, 11:42 AM
Replies 88
Views 18,893
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,195
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 598
28-09-2019, 08:22 AM
Views 380
17-09-2019, 11:52 AM
Views 663
12-07-2019, 10:36 PM
