JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Tints and windscreen 'banner'
01-03-2018, 01:29 AM
you hav around an inch and a bit from the top of the wipers to the top of the screen...
if you get on with the mot tester you might find you'll get away with it mate......
01-03-2018, 01:29 AM #11
01-03-2018, 01:34 AM
ormi you hav around an inch and a bit from the top of the wipers to the top of the screen...
Ugh inch isn't much to play with Sad Not only from the MOT side of things, but I'd rather my wipers not rub over the vinyl whenever it rains. I could have it put inside I guess, but I just don't like the look of it with a cut-out for the rear view mirror.
Maybe slightly smaller wipers would be the answer.
01-03-2018, 01:34 AM #12
01-03-2018, 01:47 AM
if you get a proper tinter to fit it you wont see any cut outs mate..
01-03-2018, 01:47 AM #13
01-03-2018, 03:05 AM
Yeah I've never really looked at it that closely but I'd imagine where the mirror meets the windscreen looks black anyway, so if the tinting is done properly you wouldn't really notice it - even if you did it would probably just look like you have a rain sensor or something :biggrin:
01-03-2018, 03:05 AM #14
Mikey
01-03-2018, 03:39 AM
Ive got minne done bit on the big side but i like it, i tinted it from the inside but my mirror is the one that attached to the roof so a bit simplier. last time i knew you were allowed a 6in strip but that was time a go.
Mikey
01-03-2018, 03:39 AM #15
dodgydave
01-03-2018, 03:50 AM
The law or regulations are based on VLT or Visible Light Transmision. This is the amount of light passing through the window and is measured with a meter. For the front side windows the VLT must not be less than 70%. This is calculated by using the correct measuring instrument by first taking a light reading from outside the car and then another from inside and the machine will calculate the VLT. As most cars these days are tinted by the manufaturer you will find that any additional tint on these windows will drop the VLT below 70% and is illigal. Apparently so I've been told Vauxhall cars actualy have the VLT etched on the glass, I don't know if this is true or not.
For this reason any reputable window tinting company will refuse to tint the front windows. If they agree to do then walk away.
My daughter got pulled over a while back in her Yaris which had all the windows tinted when she bought it. The police had the required measuring instrument and the front windows had a VLT of something like 20%. They where quite good as they just issued her with a ticket and we had to remove the film and get it verified by an MOT test station. Allthough I must admit the MOT test station dosn't have the required instument to measure with so they could only sign the ticket to say that the film had been removed.
Incedently I'm getting my rear windows tinted this Saturday and the VLT I'm going for is 18%.
dodgydave
01-03-2018, 03:50 AM #16
01-03-2018, 04:02 AM
Mikey is200/s13 Ive got minne done bit on the big side but i like it, i tinted it from the inside but my mirror is the one that attached to the roof so a bit simplier. last time i knew you were allowed a 6in strip but that was time a go.
Got any pics mate?
01-03-2018, 04:02 AM #17
Got any pics mate?
01-03-2018, 04:33 AM
I won't name names but some cars with standard glass won't pass....
01-03-2018, 04:33 AM #18
Mikey
01-03-2018, 05:47 AM
only from the first floor window
[Image: dscf1872y.jpg]
Plus ask them to see what film they will be using make sure it is Vehicle grade as some tint companys use Architectural as its cheaper & is quite a lot darker from inside the car.
My tints are not very dark but you carnt see in unless the light is on in the cabin but when i look out the window only looks like ive got a very slight tint on.
Mikey
Mikey
01-03-2018, 05:47 AM #19
Mikey
01-03-2018, 05:53 AM
Here's a pic of Mikey's motor
[Image: mikey1.jpg]
01-03-2018, 05:53 AM #20
[Image: mikey1.jpg]
Views 168
15-07-2020, 06:55 AM
Last Post by Dub///15
Views 993
09-11-2018, 01:59 PM
Views 503
06-10-2017, 04:56 AM
Last Post by jimxms
Views 823
04-01-2017, 05:04 AM
Views 972
04-08-2016, 12:58 AM
Last Post by Bandit
Views 811
03-07-2016, 03:47 AM
Last Post by Ally
