JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Cracked windscreen advice?
08-11-2018, 05:28 AM
Well I arrived at work this morning having spent all last week off ill, to find that on the journey here. My windscreen has decided to develop a crack, that originates roughly in the centre, from right down the bottom (under the plastic shield that stops **** falling into the engine bay. It then goes up about 3 inches, makes a 90* turn and then runs about 12 inches towards the drivers side and finishes almost right in front of the steering wheel. Didn't see or hear it happen, might have happened while the car was warming up this morning, could have been from a bump in the road, who knows.
Now...this will need fixing soon as with the weather like it is at the moment, I think the next time it freezes and I use the heaters it will probably span the remaining distance to the edge of the screen.
But out of any problem with the IS200, replacing the windscreen is probably the thing I least wanted to do. As I'm kacking myself after all the stories of ill fitting non-oem screens that give you leaky seals, drown your fusebox and then make your headlights stay on all the time.
So what do I do? Just phone up the insurance company, tell them I need a new windscreen but insist they fit a genuine Lexus one?
Is there any official writeup from any company etc. saying genuine screens must be used on these cars?
08-11-2018, 05:28 AM #1
08-11-2018, 05:36 AM
You have to watch the A-pillar trim also as these get damaged when replacing them.
Take the car to Lexus and say you need a screen, they will fit it and liaise with your insurance company. its your car so your choice who works on it. I bet they get Auto Glass in to do it anyway!!
Edited 20-12-2011, 03:11 PM by FirebirdPhil.
08-11-2018, 05:36 AM #2
08-11-2018, 06:00 AM
As I used to fit windscreens I may be some help, first 99% of all vehicle glass is made by pilkington, but car companies will have there own logo stamped on to it.
The myth of ill fitting glass is a good one I must say but realisticly like anything made in a factory it can sometimes be sent out with defeacts. The majority of leaking glass is down to 2 factors 1, being the size of bead used for the bond (not big enough) 2, the fitter doing the work.
I have fitted screens from Daf trucks to top of the range jags and only every now and then will I have a call back.
You can call auto glass direct and they will sort it for you.
Your screen will not fall in or shatter however the crack may get bigger but as it is a laminated screen its only the outer layer that is damaged
Hope that helps
08-11-2018, 06:00 AM #3
Hope that helps
08-11-2018, 06:04 AM
Most insurers do use Autoglass. Though when I had the drivers window smashed on my last one, they had to buy the glass from Lexus, as no alternative was available. All for £75 excess, no loss of NCB.
08-11-2018, 06:04 AM #4
08-11-2018, 06:48 AM
As long as you're insured fully comp Smile
08-11-2018, 06:48 AM #5
08-11-2018, 08:28 AM
Yes indeed, fully comp. Think my WS excess is about £90 but that's a lot more reasonable than the cost of a Lexus windscreen. Smile
08-11-2018, 08:28 AM #6
08-11-2018, 09:37 AM
It's just this 13 page long thread on the other side, of case after case of people having problems with water in fuseboxes and all sorts after having them replaced. Admitidely some of them still have the problem even without having the screen replaced, but the majority did have it changed.
I guess all I can do is make sure a genuine screen is used and cross my fingers :crying:
Edited 20-12-2011, 07:12 PM by sprinter2012.
08-11-2018, 09:37 AM #7
08-11-2018, 10:32 AM
Make them use extra sealant and it should be ok? Also make sure you book with whoever your insurer uses, Admiral for example use auto windscreens so an autoglass repair wouldn't be covered.
08-11-2018, 10:32 AM #8
08-11-2018, 10:36 AM
I've read that apparently it's the Pilkington ones that leak, around the area where the heater element wires come through.
But I'll phone them up (I do actually use Admiral funnily enough) and tell them the situation, and that an OEM one is required. That way if it's on record that I've told them it's a issue, they won't have a leg to stand on if it then leaks even though I told them.
08-11-2018, 10:36 AM #9
08-11-2018, 10:41 AM
sprinter2012 It's just this 13 page long thread on the other side, of case after case of people having problems with water in fuseboxes and all sorts after having them replaced. Admitidely some of them still have the problem even without having the screen replaced, but the majority did have it changed.
it does make you wonder but as i did it for a year i only ever had minor problems and you must take into account who/where/when they had theres done its all well and good saying mine leaks but if your in scotland and had it fitted by 1 company then someone in southampton says mine leaks and had it done by a completely different company its hard to compare the case
08-11-2018, 10:41 AM #10
Views 595
29-08-2020, 07:09 AM
Views 283
01-12-2019, 05:21 AM
Views 910
23-05-2019, 05:17 AM
Last Post by sprinter2012
Views 521
19-08-2018, 09:30 AM
Views 767
07-03-2018, 10:49 AM
Last Post by jimxms
Replies 31
Views 1,587
02-03-2018, 12:38 PM
Views 495
06-10-2017, 04:56 AM
Last Post by jimxms
Views 816
04-01-2017, 05:04 AM
Views 964
04-08-2016, 12:58 AM
Last Post by Bandit
