JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza GRRRR stupid ECU bolts!!!
Phil01
12-04-2018, 12:17 PM
How many fittings are there Marc?
Phil01
12-04-2018, 12:17 PM #11
12-04-2018, 12:21 PM
yes they are counter sunk mate
phil their is 4 in totall....two either side..
12-04-2018, 12:21 PM #12
12-04-2018, 01:09 PM
I did have the correct type of torx to take them off but ive lost the correct size one!!!!!
i will find it one day, got the rest of the set just sat there Sad
12-04-2018, 01:09 PM #13
12-04-2018, 01:27 PM
I gave mine away.....
12-04-2018, 01:27 PM #14
jomo
12-04-2018, 02:15 PM
I,v removed "safety" torx screws out of PS3's xbox 360 controllers before with just a small flat headed screw driver, find one thats the right size to cross over from one side to other side, hard to put in text but its like puting a scre3w driver at the 2pm and 10pm positions of a clock, not straight across but just round the middle nipple in the middle!
Did a bad photo but hope you get the idea!
[Image: 230628_10150183875986712_575506711_71589...0328_n.jpg]
Hope this helps.
jomo
12-04-2018, 02:15 PM #15
Hope this helps.
13-04-2018, 12:35 AM
Won't work on the ecu ones mate...far too tight...
13-04-2018, 12:35 AM #16
13-04-2018, 01:15 AM
ormi Won't work on the ecu ones mate...far too tight...
QFT.
I tried the method above and you just can't get enough grunt behind them to break them loose when using a flat head screwdriver that way Sad
I'll whip the dremel out when I get home tonight and see how it goes. Hopefully they'll come out nicely and I can just replace them with some socket cap screws. Failing that the next tool in my arsenal will be
[Image: big_ol_can_of_whoop_ass.jpg]
13-04-2018, 01:15 AM #17
QFT.
13-04-2018, 04:38 AM
Once you cut a slot just reuse them...thats what I done..
13-04-2018, 04:38 AM #18
13-04-2018, 05:24 AM
i didnt re use mine lol
13-04-2018, 05:24 AM #19
13-04-2018, 05:28 AM
Over the next few weeks my ecu is going to spend more time out than in so I may opt for quick release bolts instead :p
13-04-2018, 05:28 AM #20
Replies 35
Views 1,611
02-11-2019, 12:11 PM
Views 559
28-10-2018, 03:56 AM
Views 334
21-04-2018, 12:21 PM
Last Post by Andy-R.
Views 506
06-10-2017, 09:00 AM
