JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza rear brakes.
rear brakes.
rear brakes.
30-05-2018, 12:09 PM
the problem you have now is the handbrake and the overall size of the hub
30-05-2018, 12:09 PM #11
31-05-2018, 12:02 AM
Yeah, you can't fit the front discs on the rear. Because the handbrake shoes are inside the hub the centre part of the disc is much deeper on the rear than on the front.
31-05-2018, 12:02 AM #12
01-06-2018, 10:52 AM
ok have been thinking a bit about this. how about cutting off the rear brake disc and the same with the fronts. then welding the front outer to the rear inner, i have both front and rears left over from when i did drilled and slotted on mine, any how going to have a look at how this might work out Smile
01-06-2018, 10:52 AM #13
 4 Guest(s)
 4 Guest(s)
Views 231
01-07-2021, 06:55 AM
Views 358
25-06-2021, 09:59 AM
Views 195
27-11-2020, 12:12 PM
Views 154
07-10-2020, 01:46 AM
Last Post by Stoney
Views 482
17-08-2020, 01:08 AM
Views 632
08-01-2020, 10:54 AM
Views 357
29-07-2019, 09:39 AM
Views 631
09-07-2019, 01:02 AM
Last Post by gc8_g_r
Views 393
18-06-2019, 03:14 AM
Last Post by Kevpr
