JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS200/300 rear end differences
15-08-2020, 01:16 PM
Anyone got a definitive and accurate list of which parts are actually different about the rear end set up between the is200 and the is300?
I know the diffs are different, so I'm assuming the prop and axles will need to change with it, as well as an IS300 speed sensor? Is the subframe the same?
15-08-2020, 01:16 PM #1
iceman
15-08-2020, 02:37 PM
so are the rear lights as i asked some guy over in the usa about a set of lights for a is300 only have him say sorry will not fit my is200. ? .
iceman
15-08-2020, 02:37 PM #2
15-08-2020, 03:42 PM
rear lights are the same for the 300 and 200s
15-08-2020, 03:42 PM #3
15-08-2020, 09:55 PM
The badges are different
One says IS200
Whilst the other yeah wait for it says
IS300
15-08-2020, 09:55 PM #4
One says IS200
IS300
iceman
15-08-2020, 10:04 PM
it must be then year the as ive got a 98 plate and there for a 01 but the USA seller thinks its different its the carbon fiber once on ebay .
Edited 27-09-2013, 08:27 AM by iceman.
iceman
15-08-2020, 10:04 PM #5
16-08-2020, 01:45 AM
300's have the HID headlight leveling adjuster on the rear.
if you want to swap the subframe the MK4 supra one fits with some tweaking.
16-08-2020, 01:45 AM #6
16-08-2020, 02:55 AM
Can I still use the is rear arms if I do that though? I'm assuming that means a Soarer subframe will fit?
16-08-2020, 02:55 AM #7
16-08-2020, 03:03 AM
not sure on the arms mate, would probably be best if you could get a frame with everything still attached, and there will be a bit of modifying to do on the mouting holes at both front and rear but anythings possible with the right tools and cash.
heres the MY.is links for subframe swaps http://my.is/forums/gtsearch.php?cx=part...a+subframe
Edited 27-09-2013, 12:39 PM by is300_dino.
16-08-2020, 03:03 AM #8
16-08-2020, 12:42 PM
UK spec IS300 diff is good enough for my requirements, ~3.2 ratio which is okay. I've found a crash damaged sportcross that should do the trick. Not sure how hard it is to swap a subframe/axles etc though even if they do bolt right up.
16-08-2020, 12:42 PM #9
16-08-2020, 01:47 PM
someone on here recently removed and replaced a rear frame, wasnt that long ago cant remember who it was and cant find the post, they took photos as well.
16-08-2020, 01:47 PM #10
Views 413
13-12-2023, 02:06 PM
Views 546
09-11-2023, 03:46 AM
Last Post by Dinho
Views 926
06-11-2022, 01:49 AM
Views 3,045
02-11-2022, 10:55 AM
Views 371
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,599
23-02-2022, 01:20 PM
Views 416
18-10-2021, 02:04 AM
Views 577
03-09-2021, 11:04 AM
Views 535
29-08-2021, 09:59 AM
Replies 35
Views 8,069
04-08-2021, 04:34 AM
Last Post by cjoseph
