JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza HEADLights not switching off
m4ddy
17-06-2018, 01:18 PM
Thanks for all your replies. Ive had the car since 2004 and ive not replaced the screen, might have been b4.
So wen u say check both fuse boxes do u mean behind both the drivers kickpanel and passenger kick panel?
When i have the car started up then the front sidelights stay on and also the rear tail lights and also the inside instrument lights. So basiccly its not the headlights its the front side light, the rear tail lights and the instrument panel lights.
Even with the car off the same lights stay on, so im having to take out two fuses from the drivers side kick panel, the panel fuse (which will turn off the instrument lights) and also the tail lights fuse ( which will turn iff the rear tail light and the front side light).
Ive not checked the passenger side kick panel fuses but apart from that i dont know wat else to try.
Thanks again.
m4ddy
17-06-2018, 01:18 PM #11
Thanks again.
17-06-2018, 01:33 PM
there is a sensor under the windscreen umm you access it via the engine bay plastic bit its on the drivers side
when i had my windscreen replaced it did the same as you are describing i sealed this connector and the problem went away....
i dont have a pic of the location as it happened prior to being on any of the forums....
17-06-2018, 01:33 PM #12
Phil01
17-06-2018, 01:55 PM
what sensor andy??
Phil01
17-06-2018, 01:55 PM #13
what sensor andy??
17-06-2018, 02:02 PM
I think it's connected to the windscreen if memory serves so maybe heated glass or similar I just know it cured my lights lol ....
17-06-2018, 02:02 PM #14
18-06-2018, 11:05 AM
nah there located inside the cabin on the dash along with all wiring its def connected to the screen well it was in mine anyway lol
18-06-2018, 11:05 AM #15
 7 Guest(s)
 7 Guest(s)
Views 422
07-08-2020, 12:31 PM
Last Post by wullie_trd
Views 227
06-05-2020, 12:49 PM
Last Post by Colin G
Views 1,136
30-11-2017, 03:49 AM
Views 664
04-12-2016, 05:06 PM
Last Post by Asi
