JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning TTE front bumper + washers
25-06-2016, 07:26 AM
When you said the body shop is suggesting you "leave them out", what are you/they referring to ? Taking out the washers/actuators etc ?
25-06-2016, 07:26 AM #11
russelllinn
25-06-2016, 09:19 AM
I believe so the whole lot and blanking the pipes!!
russelllinn
25-06-2016, 09:19 AM #12
russelllinn
25-06-2016, 09:25 AM
dan_harris i'll try and get a pic up for you mate Smile
would appreciate the pic dan thanks, so can compare.
russelllinn
25-06-2016, 09:25 AM #13
25-06-2016, 10:27 AM
steviewevie When you said the body shop is suggesting you "leave them out", what are you/they referring to ? Taking out the washers/actuators etc ?
Yeah when they did mine they removed the washers and blanked the pipes and am guessing that's what they'll do here too.
25-06-2016, 10:27 AM #14
russelllinn
25-06-2016, 10:40 AM
Sounds okay though give it a slightly sleeker look a you said, have you a closer picture of yours parthiban?
russelllinn
25-06-2016, 10:40 AM #15
25-06-2016, 11:09 AM
russelllinn Sounds okay though give it a slightly sleeker look a you said, have you a closer picture of yours parthiban?
Here you go mate.....
[Image: 199595788.jpg]
Other bonus is it doesn't spray all over the bonnet when you wash your windscreen Smile
25-06-2016, 11:09 AM #16
Cous3
25-06-2016, 01:03 PM
Here's mine that I fitted, no big drama, took two of us........washers work fine and no you can't see them. I know we don't have self levelling headlights for the HID's (fitted), but headlight washers are half way there:
[Image: 371340836.jpg]
Keith
Cous3
25-06-2016, 01:03 PM #17
Keith
25-06-2016, 10:40 PM
Russell, I wonder if the mesh in your bumper is different somehow, did you get one of those bumpers without the mesh then get the mesh separately ?
25-06-2016, 10:40 PM #18
Lee
25-06-2016, 11:06 PM
I was always under the impression that the holes were marked on the inside for easy cutting. Also you will need them if you have HID's fitted.
Lee
25-06-2016, 11:06 PM #19
25-06-2016, 11:12 PM
Lee I was always under the impression that the holes were marked on the inside for easy cutting. Also you will need them if you have HID's fitted.
The legal requirement for headlamp washers with HIDs is for factory-fitted HIDs. For aftermarket HIDs, the law isn't entirely clear, and it's certainly not an MoT issue.
25-06-2016, 11:12 PM #20
 3 Guest(s)
 3 Guest(s)
Views 308
28-03-2021, 02:01 AM
Views 362
06-10-2019, 10:59 AM
Last Post by jomo
Views 626
24-08-2018, 04:44 AM
Last Post by Lexuslee
Views 824
01-07-2018, 07:31 AM
Last Post by bash6673
Replies 22
Views 1,438
28-01-2018, 03:48 AM
Last Post by karlp
Views 1,094
01-01-2017, 05:02 AM
Last Post by Asi
Views 518
21-10-2016, 01:46 PM
Last Post by Rolex
Views 644
17-06-2016, 10:56 PM
