JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications IS300 Intake on Supercharged IS200
16-08-2018, 03:43 AM
Sparkystav Dean has one on his IS300, i was looking at it at JAE, it must restrict to an extend because when he rev'd the engine it sucked onto the filter and off again.
Yeah, I figured there is no way it could not restrict airflow, even if it was just a little bit? Though I am interested how it effects the sound. Would it muffle it a little? Mine is LOUD!
16-08-2018, 03:43 AM #11
16-08-2018, 05:29 AM
Just done some measuring and from the back edge of the radiator header tank to the back edge of the scoop outlet is 45mm.
:offtopic: I would imagine it does VERY slightly restrict airflow, mine isn't ridiculously tight around the filter so air can flow in through the ends as well as through the mesh.
However think of it like this...whats more restirctive, a mesh designed to let air through it, or a wet filter full of dirt and flies? :thumbup1:
With regards to noise, makes absolutely NO difference whatsoever. lol
16-08-2018, 05:29 AM #12
16-08-2018, 05:42 AM
sprinter2012 Just done some measuring and from the back edge of the radiator header tank to the back edge of the scoop outlet is 45mm.
I forgot to check at lunch! But should have half a day at home tomorrow and will get my tape out then and measure the charger parts positions.
EDIT: 45mm sounds a lot! I don't think there is that much clearance between the header tank and the belt, though I will post once I have actually measured.
Edited 27-09-2011, 03:18 PM by Stoney.
16-08-2018, 05:42 AM #13
17-08-2018, 07:48 AM
Right. To answer the initial question: NO.
The scoop will not fit with a charger.
Sprinter measured 45mm clearance required. I make the clearance from the back of the header tank to the charger pulley 18mm. NO WAY it would fit. The scoop occupies the space that the entire charger pulley sits in! As shown in the pic.
Also, the pipe I mention that my belt wore through before, was not the one on the side that is essentially a breather, it was the pipe from rad to expansion tank. This pipe has just 4mm clearance from the spinning belt, in it's stock location. Again, as shown in the pic.
Pics for comparison:
(Sorry out of scale!)
[Image: 2011-09-28134806.jpg]
[Image: DSC00558.jpg]
Edited 28-09-2011, 05:24 PM by Stoney.
17-08-2018, 07:48 AM #14
Talisker
23-08-2018, 02:44 AM
That's most disappointing I was really hoping it would fit although I'm fairly sure it could be modified somehow to fit.
It's a real shame there aren't more of those gucci carbon intakes kicking around, I'd really like to get my hands on one of them.
Talisker
23-08-2018, 02:44 AM #15
23-08-2018, 03:05 AM
The only way it would work would be if you cut a massive section off the back of the intake. You would reduce the airflow by more than 50% on order to get it to clear the charger, and that would render it almost pointless, for the low air flow it would provide.
23-08-2018, 03:05 AM #16
23-08-2018, 05:22 AM
Have you guys thought about cutting a 60mm hole behind the drivers side headlight and running the intake down throught here into the empty space in front of the wheel arch?
Would be well out of the way of any heat from the engine, and also benefit from being fed air directly from the louvre in the bumper next to the fog light?
You could then run a filter cover over the top of your air filter to stop a lot of the bugs/water from getting into the filter increasing the service life.
Yes you'd have a hole when you come to sell the car, but a tiny bit of creative thinking is all it would take to cover it up Wink
Edited 04-10-2011, 02:57 PM by jimxms.
23-08-2018, 05:22 AM #17
23-08-2018, 05:37 AM
I have considered many options, and concluded I have lots of other things to be concentrating on at the moment, and I'm gonna leave it how it is, and revisit this idea later! Though something like that is a good option Jim.
23-08-2018, 05:37 AM #18
23-08-2018, 05:42 AM
I plan on doing this while i'm changing bumpers in a few weeks. (Remember you helped me find the vent outlet Jim?) There's a how-too thread on here somewhere called 'ram air anyone?' which shows how to do it Smile
23-08-2018, 05:42 AM #19
Talisker
23-08-2018, 10:32 AM
jimxms Have you guys thought about cutting a 60mm hole behind the drivers side headlight and running the intake down throught here into the empty space in front of the wheel arch?
I've cut a hole there already and fabricated a cold air box out of sheet aluminum Big Grin. I was just being greedy and wanting more air, and something that looked a little more OEM.
Talisker
23-08-2018, 10:32 AM #20
Views 1,772
05-07-2023, 05:08 AM
Last Post by damtrx
Views 828
17-04-2023, 03:51 AM
Views 1,424
05-04-2023, 03:19 AM
Last Post by damtrx
Views 767
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 306
29-11-2022, 03:38 AM
Last Post by phaebo
Views 483
04-11-2022, 05:54 AM
Views 402
30-04-2022, 06:27 AM
Views 606
27-04-2022, 12:45 PM
Last Post by oedipus
