JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Running hids non oem??you might just find they are now legal!!!!woopwoop
23-08-2018, 12:41 PM
is300_dino result! now to tackle the rest of the reguations lol.
what like mate?everyones been going on about them and they are not that bad.......ok heres a read for yous all.......its about all the regs
First the good news. After consultation with a number of agencies and organisations the proposed changes to the MOT system to be implemented in January 2012 have been amended. Therefore:
• There will NOT be a total ban on the use/sale of aftermarket HID kits, which was a major part of the proposal. The current MOT rules state
High Intensity Discharge (HID) and LED dipped beam headlamps (whether original fitment or after-market) must be fitted with a headlamp washing system (a wiper is not required) and be self levelling. This may be achieved by the use of either headlamp or suspension levelling systems. However, some high performance vehicles fitted with HID headlamps that have limited luggage space and stiff suspension do not require a self-levelling system.
Reason for failure: A mandatory headlamp levelling or cleaning device missing, inoperative or otherwise obviously defective
• There will not be a ban on “illegal” engine tuning. Frankly there was no way a visual inspection could identify an aftermarket chip or re-map anyway, and this proposal was met with universal contempt by MOT testers. The only reference in the new manual to this is that modified cars must meet the correct emissions level for the year of engine.
Changes to the MOT that could affect lowered cars
These are the changes that have been implemented.
• Check that there is enough clearance of the axle or suspension with the bump stop or chassis
• Check that there is sufficient clearance from body to wheels
Reason for failure:
Inadequate Clearance of the axle or suspension with the bump stop or chassis.
Inadequate clearance between body and wheels.
Deliberate modification which significantly reduces the original strength, excessive corrosion, severe distortion, a fracture or an inadequate repair of a load bearing member or its supporting structure or supporting panelling within 30cm of any sub-frame, spring or a suspension component mounting, that is, within a ‘prescribed area
The key word in the first definitions is ‘inadequate’. This leaves it to the discretion of the MOT tester on what classes as inadequate. It’s not a massive problem, as I’d imagine most lowered car owners will have a friendly MOT tester that they use anyway. If not it might be time to find one. The 2nd part is interesting, for instance a chassis C notch could be seen as reducing the strength of the supporting structure for the front subframe.
That’s about all we can find that affects modified cars in the new manual, so much better than first thought.
Vehicle Registration Laws
There are 2 different organisations involved in this process.
The DVLA maintain the database that contains all the drivers and all the vehicles in the UK.
VOSA regulate the MOT test and perform roadside checks to improve road safety.
The “8 points” Registration System
To put this system into context, people must understand that you never own the registration document for a vehicle. It is purely on loan and they can remove the right to registration if a problem arises.
The “8 points” system is how they determine whether a car should retain its original registration. First they assign each major part of the car a set point score like this.
• chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
• suspension = 2 points
• axles = 2 points
• transmission = 2 points
• steering assembly = 2 points
• engine = 1 point
To retain it’s original registration, the vehicle must score 8 or more points from this list. However this must always include the 5 points for the original UNMODIFIED monocoque shell/chassis. This doesn’t sound too bad, but say for a Mk2 Golf with a VR6 or 1.8T conversion, aftermarket suspension and a disk brake axle on the rear you’d have 7 points. The problem with this system is that if/when you take your car to be DVLA inspected it is down to the tester’s discretion on whether he allocates the points or not. The DVLA actually define each part as "the original part that the vehicle left the factory with". Obviously this is impossible to implement, as all the parts listed have at least a fair chance of being replaced throughout the life of a vehicle, not for modification but for warranty claims and servicing. For instance it's fair to say that if you go to a test with performance suspension parts fitted rather than OEM standard replacements you will lose those points.
What constitutes an Unmodified Monocoque?
Firstly it’s probably best to explain what a monocoque shell constitutes. From the DVLA definition:
“What constitutes a monocoque is that of how an OEM manufacturer would view it. The chassis or `cage` assembly and all components that form it, less any cosmetic panels or infills that make no structural consideration to the monocoque or its component parts.”
That bit basically.
What this means
Your car WON’T need an IVA if you:
• Roll/Flare the wheel arches
• Fit different cosmetic panels (i.e. front end conversion, US/JDM body panels)
• Fit a roll cage (aslong as the existing shell isn’t cut to fit it – holes through bulkhead to fit bracing bars to strut tops a no-no for instance)
• Fit/remove a sunroof aslong as you don’t chop any strengthening members.
• Convert a car to a van – as you are adding to the existing structure.
Your car WILL need an IVA if you:
•C notch the chassis legs for driveshaft clearance
•Raise the strut tops
•Modify the floor or bulkhead
•Chop the roof off/convert to a pickup
•Cut the outer arch lip for tyre clearance/to fit a wide arch kit, as this is classed as a structural area
•Modify any part of the monocoque
From reading the DVLA rules as long as you don’t add to the width or length of the vehicle it is fine to add strength to the monocoque. Therefore if you weld plate over the existing chassis legs and fill the holes in the bulkhead to smooth an engine bay you should be fine. However if you cut the bulkhead out and weld in a complete flat sheet section, or chop the chassis legs out and refabricate in box section you will be liable to IVA the vehicle.
How is this enforced?
These seem to be the main ways that people are caught in contravention of the rules:
• Changing body type on V5 – If you send off the V5 with the body type changed it will automatically flag up the car for an inspection.
• VOSA/Police Spot Check – If you are pulled into a VOSA/Police checkpoint they can pass information onto the DVLA if the vehicle is not what it says on the log book.
• Flagging up modified vehicles for inspection at shows and from magazine articles - keep your registration plates/chassis number (if visible to outside i.e. in windscreen) hidden if possible to make it more difficult.
There is a rumour flying around that they are going to give the MOT tester a “modified vehicle” button which he has to check if a modified vehicle goes for an MOT. If this is checked it will flag the vehicle up for inspection. However there is no evidence to say this is in the pipeline.
What happens if my car is flagged for inspection?
If your car is flagged for inspection you will be summoned to the nearest DVLA office. A trained inspector will then go over the car allocating points based on the above values. If the car passes the inspection the vehicle will retain its registration certificate. If the car doesn’t pass the inspection it’s registration certificate will be revoked, meaning that the car cannot be used on the road.
To re-register the vehicle it must pass through an IVA test.
The IVA test
The IVA test is a stringent inspection to register amateur built/radically altered vehicles. It was implemented as the old SVA test had no class for inspecting radically altered vehicles.
The test is too stringent to go into in a forum post. There is a PDF of the manual here
http://mcelroymotors...0may%202009.pdf
Most cars post mid 70s are type approved, and therefore in standard form should easily pass an IVA test. However in modified form it may be more difficult. There is definitely no way that a car running poke, stretched tyres or scrub line interference will pass. The best thing would be to print a copy of the manual off, buy a radius tool off ebay and go through each pointer making sure it will pass. It's laborious, but on the plus side it will give you an insight into how much though goes into designing a car to pass crash safety tests.
Costs
The costs of an IVA test are fairly high, around £450 (no vat), then £99 (no vat) for a re-test if you fail.
Chances of getting caught
Put simply, there is no way of knowing. There are thousands of cars that are still using their original registration number when they should be having an IVA test. You could drive around for 10 years and never get a whiff of an inspection, but on the other hand you could apply to swap onto a private plate, or an engine swap, and get flagged for inspection. It really is pot luck, but as time goes on there is a good chance they’ll find new ways to catch people out.
There is a current proposal that the DVLA local offices will be closed and their powers given to the Police/VOSA. Apart from the fact that it will mean the people doing the inspections will be more clued up on modified vehicles, I feel it could also give more ammunition to the police to clamp down on modified cars that whilst not necessarily illegal in basic terms (MOT, tax, insurance present) fall foul of the regulations.
http://www.the-ace.org.uk/
The Association of Car Enthusiasts aims to report on and fight against forthcoming vehicle legislation that has a damaging effect on the modified car "hobby".
23-08-2018, 12:41 PM #11
Reason for failure:
• axles = 2 points
• engine = 1 point
That bit basically.
What this means
The IVA test
Costs
23-08-2018, 12:43 PM
sprinter2012 Resultttt, better get my coilovers fitted before the next MOT then. lol
Same for me. Though I have nearly 11 months! How it doesn't take me that long though.
23-08-2018, 12:43 PM #12
23-08-2018, 01:16 PM
just the emissions one will do, its nice not having a cat, it should be 'if theres black smoke coming from the exhaust, fail' not because its .0002% over the limit or however its done.
23-08-2018, 01:16 PM #13
Phil01
23-08-2018, 02:02 PM
I think we may be reading between the lines here,,,
When they say high performance cars I am guessing they do not mean Modded cars with coilies and a boot full of stereo install.
I can bet they mean super or hyper cars that left the factory as intended, built as a proper high performance 160mph+ cars, where they were designed for speed.
I believe it is our mis-interpretation of the ruling to makes us feel better.
I may be wrong and I hope I am because I will fall into the new ruling, but Don't go counting your chickens just yet
Phil01
23-08-2018, 02:02 PM #14
23-08-2018, 02:15 PM
they do not specify what cars come under that ruling also they cant single out cars unless they list the cars their is no catagory for cars to fall in too(its a loop hole they never thought of..lol)...whats good for one car is good for another..
23-08-2018, 02:15 PM #15
Phil01
23-08-2018, 02:20 PM
but are the new rulings set in stone yet because you know as well as I do that VOSA can and make amendments to sub paragraph what ever at anytime.
I still think it is a bit premature for us to think we have found a loophole and a valid way to get around it.
I do hope im wrong but I aint rushing out to get stiff springs just yet
Phil01
23-08-2018, 02:20 PM #16
Phil01
23-08-2018, 02:23 PM
any way, whats the hardship in refitting halogen bulbs on the day of test, because that is when the test is valid,
It does not mean and not passed as law at all that hids are illegal, just it will be an mot failure at time of testing
Phil01
23-08-2018, 02:23 PM #17
23-08-2018, 02:34 PM
i think the plan was to ban them because of that..the way i see it is if they are alighned correctly i dont see the issue...and it theirs too much beam scatter just rotate the bulb very slightly if poss and that normally sorts it..but i dont see the benifit to all these new rules...
23-08-2018, 02:34 PM #18
Phil01
23-08-2018, 02:40 PM
^^ nor do I marc, the new rulings are rubbish and I hate vosa with a passion. When they come into a dealership they really do act like little hitlers and we all have to do what they say.
That is the main reason after working 35yrs in the motor trade not once did I want to put my name forward as an MOT tester.
Phil01
23-08-2018, 02:40 PM #19
04-09-2018, 10:56 AM
Have things got a lot stricter now regarding HIDs? Or is it pretty much the same? Don't really want to get pulled over for having them...........
04-09-2018, 10:56 AM #20
Views 599
08-04-2021, 11:45 PM
Last Post by ozzie b
Replies 26
Views 1,353
20-03-2019, 03:09 AM
Views 808
07-01-2019, 01:58 AM
Views 404
18-06-2018, 12:23 AM
Last Post by Stoney
Views 513
05-06-2018, 06:09 AM
Last Post by Bonney
Views 545
20-11-2017, 03:44 PM
Last Post by Dark Samurai
Views 820
30-05-2017, 10:43 AM
Replies 33
Views 1,557
05-01-2017, 12:30 AM
Last Post by kam05
