A Little Advice
A Little Advice
Sparkystav But remember they are not just for snow but for any low temps, normal summer tyres wont be anywhere near as good in sub 6-7 degrees cYou're right. Summer tyres get rock hard in the cold. Winter tyres have a much softer rubber mixture which means better performance when it's cold. It also means they get worn quicker, that's why want to swap back to summer tyres when the weather gets warmer.
lebon Currently I am on 225/45/17 at the front and 245/45/17 rears, is it ok to have the 225/45/17 for the rears too as my winter tyres. If its ok would it have any impact on the handling?The wider tyres you've got the bigger the risk of hydroplaning on wet roads and snow. Rally drivers use super narrow tyres to be able to cut through the mud, snow and water rather than hydroplaning on top of it.
225 all round is better. i say get the best you can aford, with winter tyres ever little helps, i'm running conti cvc5 225/40/18 and putting out a lot more bhp now and drive the car every winter and for 3 years i've not fell off the road or got stuck
lebon Thanks for the advice but I have 17' rims so is it ok for me to have 225/45/17 all around or do I have to stick with 245/45/17 at the rears
lebon Thanks Jay/Stoney, never knew before this that you could use 225 all around thought you had to stick to what was there i.e 245. Was thinking of fitting nankangs but decided against it probably get a premium part worn tyres instead.
Quote:For the IS250, standard OEM wheels after 2006 have 8" wide fronts and 8.5" rears. The very first cars had 8" all round but still had wider tyres on the rear.
lebon But are you able to fit 255/40 on a 17' rims or is there more to it.
depends on the width of the wheel
