Pages (51): Previous 118 19 20 21 2251 Next
04-03-2020, 04:47 AM
Fair enough. This year unlikely?
04-03-2020, 04:47 AM #191
04-03-2020, 04:49 AM
Sparkystav Fair enough. This year unlikely?
Perhaps towards the end of the year... next year more likely though. It'd be much easier (but colder) to get all the finishing touches out of the way over the winter.
04-03-2020, 04:49 AM #192
04-03-2020, 05:55 AM
Fair play mate, it is a big project.
04-03-2020, 05:55 AM #193
08-03-2020, 10:18 AM
Oil relocation plate has arrived. £4 import charge and £8 handling fee from good old Royal Fail.
08-03-2020, 10:18 AM #194
08-03-2020, 02:37 PM
Not royal mail - HMRC customs and Excise...........
08-03-2020, 02:37 PM #195
08-03-2020, 03:28 PM
Lol makes me so angry they still get away with the 'holding your parcel to ransom' charge.
08-03-2020, 03:28 PM #196
12-03-2020, 10:52 AM
toxo Bought this today.
[Image: 1089.JPG]
[Image: 1090.JPG]
[Image: 1091.JPG]
Combining this with an oil filter relocation kit (basically use this plate instead of the sandwich plate that would go on the engine in such a kit) should eliminate the problems with the oil filter meeting the steering rack.
Collected this from the posties today... it will do the job but I won't be buying anything else from them. There's a LOT of swarf left from where they've cut one thread into another and that's not really what you want in oilways! So I will clean it up myself to be sure.
Have also got the replacement part for the starter motor from Mr T so I can rebuild that now as well.
Edited 23-04-2012, 02:38 PM by toxo.
12-03-2020, 10:52 AM #197
[Image: 1089.JPG]
[Image: 1090.JPG]
[Image: 1091.JPG]
16-03-2020, 03:24 PM
Had today off work to do more on the engine, was planning on having a productive day but didn't really work out that way!!
Started off by repairing the starter motor. Fairly straightforward, swap broken piece of metal for non broken one :lol:
[Image: IMG_20120427_112228.jpg]
Regreased all the bearings and stuff and reassembled. I reinstalled the motor between the V having cleaned up the hole that it slots through so that it hopefully won't get jammed again.
Then I sanded the paint runs out of the timing belt cover I sprayed last week and resprayed, and then did 4 coats on the other timing belt cover. After that I started on the intake manifold...
Here's the underside of it. It's a fairly complicated design once you factor in the ACIS system. The centre of the manifold forms the surge tank / plenum of the intake system, then ACIS opens and closes 1 route through the intake to lengthen or shorten the intake tract. It's nothing new, most Toyota engines do this, but they're not usually 8 cylinders - it's a lot to fit into a small space and very cleverly designed.
[Image: IMG_20120427_120119.jpg]
And ACIS butterflies removed:
[Image: IMG_20120427_170907.jpg]
I popped to MK to get some nitromors and when I got back the roof had leaked onto the belt covers that I'd been painting Confusedhock: Not pleased.
Then I realised I'd covered the intake manifold in nitromors to strip the paint off but the parts washer was full of ****, so I spent the rest of the afternoon cleaning that out. Cleaned all the paint stripper off the intake manifold but it needs another going over and I was ****** off by then so I went home!
16-03-2020, 03:24 PM #198
mattlaw
16-03-2020, 04:53 PM
Sounds like a rough day mate
mattlaw
16-03-2020, 04:53 PM #199
16-03-2020, 06:13 PM
Lol days like that are **** but you'll get there.
16-03-2020, 06:13 PM #200
Views 3,064
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 1,997
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 1,043
21-05-2024, 04:24 AM
Replies 362
Views 39,434
06-08-2023, 02:50 PM
Last Post by john wan
Replies 1,318
Views 118,920
05-06-2023, 02:12 PM
Last Post by sarah0
Views 3,683
03-03-2023, 03:41 PM
Views 2,138
16-11-2022, 05:59 PM
Views 4,379
11-11-2022, 06:59 AM
Replies 46
Views 9,322
19-10-2022, 08:00 AM
Replies 53
Views 9,395
18-10-2022, 06:53 AM
