JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! DIY custom supercharger parts list
Pages (21): Previous 117 18 19 20 21
lexus971
04-04-2024, 02:31 AM
Hello, I am also on a compressor preparation on my lexus is 200, the set of parts are mounted but I have unimmer with the electronic management. Is that the ecu of the lexus is 200 standard is the same as that of the lexus Is there 200 compressor header? I have a project to use a website using a website and a hcs fcd is that fit? I really need help i am lost
lexus971
04-04-2024, 02:31 AM #201
04-04-2024, 03:12 AM
An FCD will work, but you really want a voltage clamp black box from p.lindbom on here
04-04-2024, 03:12 AM #202
lexus971
04-04-2024, 02:41 PM
I have currently plugged my piggyback aem f / ic6 but I was told that it will take me a fcd hks. My car is cut at about 2 psi. Do you need a fcd? Lexus is 200 standard and is 200 head compressor have it the same ecu?
Thank you
lexus971
04-04-2024, 02:41 PM #203
Thank you
04-04-2024, 03:43 PM
Sorry I don't quite understand.
Do you have a supercharged is200? Then it needs a voltage clamp of some kind
04-04-2024, 03:43 PM #204
lexus971
04-04-2024, 04:16 PM
Yes my car is supercharged, I have a problem on the electronic management. Should I put a fcd hks with my piggyback aem f / ic6
lexus971
04-04-2024, 04:16 PM #205
lexus971
04-04-2024, 04:32 PM
I want to reach 250 horsepower
Lexus is 200 supercharger eaton m62, bypass mini cooper s, piggyback aem f /ic6, pulley 145mm, pulley compressor 83mm, intercooler 550x180 mm .
lexus971
04-04-2024, 04:32 PM #206
05-04-2024, 08:04 AM
Ah I understand. There should be the setting within the aem to act like an fcd already
05-04-2024, 08:04 AM #207
lexus971
05-04-2024, 02:45 PM
Thank you for your answer, aem f / ic6 is enough? I can not change the ignition with this case is what is a problem?
lexus971
05-04-2024, 02:45 PM #208
05-04-2024, 03:57 PM
It's the map sensor that the fcd clamps. The aem should be attached to that signal.
05-04-2024, 03:57 PM #209
lexus971
06-04-2024, 05:29 PM
Thank you
lexus971
06-04-2024, 05:29 PM #210
Thank you
Views 1,602
21-03-2024, 04:36 PM
Views 2,006
07-04-2021, 04:23 AM
Last Post by daveo
Views 1,092
29-08-2020, 10:01 AM
Views 1,113
12-09-2019, 12:32 PM
Views 923
10-06-2019, 10:02 AM
