JapCarForum Cars, Cars, Cars! Project Cars It's a Supra Thing.....
Pages (25): Previous 121 22 23 24 25 Next
30-01-2019, 04:52 AM
Here you go Stav the brackets, clips and bolts, if you want some more detailed or close up of the brackets lemme know Smile they are seriously solid though
[Image: 15q44zn.jpg]
30-01-2019, 04:52 AM #221
mplavery
30-01-2019, 05:22 AM
Looking good Dan, as said your ment to have a better feel on the pedal on the K-sports to UK's
I really wanna set of these lol
Now hurry up and put them on lol
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
30-01-2019, 05:22 AM #222
[/COLOR]
[/COLOR]
30-01-2019, 05:36 AM
mplavery Looking good Dan, as said your ment to have a better feel on the pedal on the K-sports to UK's
Yeah mate i did hear that, as soon as i've got them on you can take her out and see how it compares brake wise to yours as a kind of 'try before you buy' if you like?
30-01-2019, 05:36 AM #223
mplavery
30-01-2019, 06:13 AM
Dan_Turism0 Yeah mate i did hear that, as soon as i've got them on you can take her out and see how it compares brake wise to yours as a kind of 'try before you buy' if you like?
Sounds good to me, you can take mine for a spin too
[/COLOR]
[/COLOR]
mplavery
30-01-2019, 06:13 AM #224
[/COLOR]
[/COLOR]
30-01-2019, 06:35 AM
Dan_Turism0 Here you go Stav the brackets, clips and bolts, if you want some more detailed or close up of the brackets lemme know Smile they are seriously solid though
No that pictures spot on.
That's the sort of bracket I'll have to make for the LS calipers if I can't get the uk spec supra ones to fit.
30-01-2019, 06:35 AM #225
30-01-2019, 06:51 AM
mplavery Sounds good to me, you can take mine for a spin too
Noooooooooooooooooooooooo.... no spinning!
30-01-2019, 06:51 AM #226
mplavery
30-01-2019, 07:26 AM
purplewitch Noooooooooooooooooooooooo.... no spinning!
lol you got to get the ass end out !.. one of the best bits about driving is spinning the rear wheels due to the power of the car lol
Edited 12-03-2012, 05:04 PM by mplavery.
[/COLOR]
[/COLOR]
mplavery
30-01-2019, 07:26 AM #227
[/COLOR]
[/COLOR]
30-01-2019, 08:03 AM
[COLOR="DarkOrchid"]ahh spinning wheels Smile ok...
no spinning of car though[/COLOR]
30-01-2019, 08:03 AM #228
30-01-2019, 09:01 AM
mplavery lol you got to get the ass end out !.. one of the best bits about driving is spinning the rear wheels due to the power of the car lol
Like at Ace, right Big Grin
30-01-2019, 09:01 AM #229
07-02-2019, 07:33 AM
Ok guys the KSports are now on and my word what a difference they have made coupled with braided lines the pedal feel is 10x better and the car now no longer feels like it's trying to kill me which is the main thing.
After a evening at the J-Unit and massive thanks to John we set about changing the brakes over and after removing my nearside which i knew had the siezed piston however had no idea of the effect it had on my discs and the pads (which i had only changed a few months ago). Upon getting the caliper off we discovered the following
heavily pitted disc and a lip on both inside and outside of the disc not good by any means
[Image: IMGP3415.jpg]
this was further confirmed when you see the state of the pads that came off, very heavy scoring and wear on the bottom of the inside pad.
[Image: 2012-03-20152326.jpg]
It was then time to test fit the bracket and see how much we would need to cut/bend the dust shield (which turned out to be quite a lot) as the new discs are over 30mm larger than my old ones
[Image: IMGP3414.jpg]
After modifications to the dust shield and tests to check the disc would rotate perfectly without catching the shield finally one side was assembled (apologies it appears the previous owner had a thing for painting everything in sight red!)
[Image: IMGP3416.jpg]
Process was then repeated on the other side and now the KSports fit nicely behind my 18's Smile
[Image: 2012-03-20085511-1.jpg]
I'm glad I didn't opt for the 356mm discs as I doubt they would fit behind my wheels
07-02-2019, 07:33 AM #230
 5 Guest(s)
 5 Guest(s)
Replies 257
Views 22,333
03-01-2024, 08:24 AM
Views 901
31-10-2023, 10:05 PM
Replies 79
Views 4,282
03-09-2023, 10:30 AM
Replies 29
Views 3,280
29-08-2022, 01:37 AM
Last Post by Berg
Views 2,181
06-05-2021, 10:24 PM
Last Post by Connor376
Replies 53
Views 4,250
02-03-2021, 10:06 PM
Last Post by TheAmerican
Replies 39
Views 2,892
20-01-2021, 04:47 AM
Replies 132
Views 5,390
11-11-2020, 01:34 PM
Last Post by japgirl
Views 825
27-09-2020, 03:43 PM
Last Post by purplewitch
Replies 106
Views 5,354
05-09-2019, 12:12 PM
Last Post by racestyle
