Pages (51): Previous 121 22 23 24 2551 Next
19-06-2020, 03:28 PM
Doh!
http://www.ebay.com/itm/New-Wilwood-Mast...0473214899
19-06-2020, 03:28 PM #221
Doh!
19-06-2020, 03:30 PM
Depends on clearance. Obviously the M/C has to be attached directly to the pedal, so if I keep the standard pedals I have to have the M/C in the stock position. To completely eliminate it from the firewall (if that's needed) then I'll need to use a pedal box.
Either way will involve ABS deletion too... Like I said, we shall see!
19-06-2020, 03:30 PM #222
20-06-2020, 07:45 PM
Started putting it all back together. Not looking too bad... still missing some cam covers though!
[Image: IMG_20120801_195607.jpg]
[Image: IMG_20120801_195615.jpg]
20-06-2020, 07:45 PM #223
21-06-2020, 05:05 AM
nothing is better then a V8 - a clean v8 is even better:w00t:
21-06-2020, 05:05 AM #224
21-06-2020, 10:42 AM
Now in my posession:
[Image: IMG_20120802_122321.jpg]
21-06-2020, 10:42 AM #225
26-06-2020, 06:16 PM
Stripped the box of the bellhousing, slave cylinder, rear mount etc so that I could test fit:
[Image: IMG_20120807_200719.jpg]
This has the propshaft fitted into the back of the gearbox, but it's just held on the jack for positioning. It's *roughly* in the right place. This is how it lines up:
[Image: IMG_20120807_200749.jpg]
As you can see, it's about 3cm too far forwards (you can see the alu prop behind the shifter). It's going to a gearbox place before the car's finished to get some hardened parts in it, so I will ask if they can cut and weld the shifter assembly to move it further back.
Edited 07-08-2012, 10:02 PM by toxo.
26-06-2020, 06:16 PM #226
Marcus_1UZ
01-07-2020, 07:19 AM
well done mate, Smile
Marcus_1UZ
01-07-2020, 07:19 AM #227
01-07-2020, 11:52 AM
getting there how much longer do you think it will take ?
01-07-2020, 11:52 AM #228
01-07-2020, 05:44 PM
No idea. I am waiting on a rear gearbox mount from Toyota that's got to come from Japan, so it won't be here until the end of the month. Then I can check final clearances and stuff on the box in its correct position. Then I need to find a decent gearbox place round here who can strip the box and change the thrust washer, output bearing plate and 1st/2nd gear selector fork... And that's just the gearbox!! Still need about £2.5k of engine bits to make it all fit together. Like I've said before, I'm in no rush. Probably not going to buy anything more for it for a couple of months.
Edited 13-08-2012, 03:03 PM by toxo.
01-07-2020, 05:44 PM #229
20-07-2020, 11:25 AM
Gearbox mount has finally turned up! Overnight parts from Japan my ****...
20-07-2020, 11:25 AM #230
Views 1,908
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 1,464
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 741
21-05-2024, 04:24 AM
Replies 362
Views 31,991
06-08-2023, 02:50 PM
Last Post by john wan
Replies 1,318
Views 96,773
05-06-2023, 02:12 PM
Last Post by sarah0
Views 2,848
03-03-2023, 03:41 PM
Views 1,828
16-11-2022, 05:59 PM
Views 3,915
11-11-2022, 06:59 AM
Replies 46
Views 7,958
19-10-2022, 08:00 AM
Replies 53
Views 7,767
18-10-2022, 06:53 AM
