Pages (51): Previous 122 23 24 25 2651 Next
20-07-2020, 03:14 PM
MK Gearboxes are good - Tavistock Street Bletchley.
Filthy grubby place but know their gearboxes.
20-07-2020, 03:14 PM #231
03-08-2020, 06:42 PM
Cheers for that Phil.
After all the fun of the Nissan over the last month or so it's time to get back on this! I properly bolted in the gearbox today with the new rubber mount that I got from Toyota (new bolts too - I only had shitty ones and I doubted they were up to the job).
Here are some pics, some decent detail of the mounting bracket, prop, shifter position and how the gearbox sits. With it all bolted up you can select every gear as long as there's no trim on! It means I can at least build the car and use it before getting the gearbox work done. You can also get an idea of just how clean the underside of this car is!
[Image: IMG_20120914_191204.jpg]
[Image: IMG_20120914_191231.jpg]
[Image: IMG_20120914_191239.jpg]
[Image: IMG_20120914_191304.jpg]
[Image: IMG_20120914_191310.jpg]
[Image: IMG_20120914_191316.jpg]
[Image: IMG_20120914_191329.jpg]
Then I fitted the custom front subframe to the car for the first time, to do some more measurements. It looks like the engine mount on the driver's side is in the right place, so the one on the passenger side needs to move forwards 30mm so it's in line with the driver's side one.
[Image: IMG_20120914_193914.jpg]
Bad news is it looks like the head WILL contact the clutch master cylinder. But we shall see.
Edited 14-09-2012, 11:17 PM by toxo.
03-08-2020, 06:42 PM #232
14-08-2020, 06:53 PM
I know it's payday soon.. so.... KABUMP
14-08-2020, 06:53 PM #233
15-08-2020, 05:02 PM
el_bandido I know it's payday soon.. so.... KABUMP
I'll give you a clue... you put 1 thing in and get 2 things out.
15-08-2020, 05:02 PM #234
15-08-2020, 05:18 PM
toxo I'll give you a clue... you put 1 thing in and get 2 things out.
You're having twins?
15-08-2020, 05:18 PM #235
15-08-2020, 05:28 PM
clutch master cyl relocate it is then Big Grin
15-08-2020, 05:28 PM #236
19-08-2020, 09:41 AM
Auto diff purchased Wink Lowers the rear ratio from 4.1:1 to 3.9:1. Short of fitting a cobra diff (new rear subframe, custom driveshafts) or the HKS final drive kit (3.7:1) both of which start at £2k this is the best I can do to sort out the final drive ratio so it better matches the R154.
It has since occured to me that as the previous owner was running an R154 in the car, it may already have an auto diff. I need to find out if there are any external marks on the casings to indicate which final drive they have, or if not open them up and count teeth!
I have worked out another easy option for moving the gearbox rearwards a bit more as well, but it remains to be seen if that will cause engine mounting issues or not. I suspect it will stay where it is.
Edited 30-09-2012, 01:28 PM by toxo.
19-08-2020, 09:41 AM #237
19-08-2020, 09:49 AM
Clutch relocation if it has to happen will involve a pedal box, likely a Tilton 600 or similar.
19-08-2020, 09:49 AM #238
19-08-2020, 10:58 AM
Mmm pedal box. Nice bits of kit.
19-08-2020, 10:58 AM #239
19-08-2020, 11:00 AM
Expensive bits of kit! Right way to do it though.
19-08-2020, 11:00 AM #240
 5 Guest(s)
 5 Guest(s)
Views 1,908
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 1,464
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 741
21-05-2024, 04:24 AM
Replies 362
Views 31,994
06-08-2023, 02:50 PM
Last Post by john wan
Replies 1,318
Views 96,785
05-06-2023, 02:12 PM
Last Post by sarah0
Views 2,848
03-03-2023, 03:41 PM
Views 1,828
16-11-2022, 05:59 PM
Views 3,915
11-11-2022, 06:59 AM
Replies 46
Views 7,961
19-10-2022, 08:00 AM
Replies 53
Views 7,767
18-10-2022, 06:53 AM
