JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications 280BHP Super charged IS200 Engine for Sale on eBay
Pages (3): Previous 1 2 3
25-06-2020, 12:57 AM
*BUMP*
Just seen this thread. What happened with this setup then Mr. Quinn? I'm sure there was a car with this setup in it for sale on ebay the last couple weeks?
25-06-2020, 12:57 AM #21
*BUMP*
reganlives
25-06-2020, 02:37 AM
You mean the black one that was for sale? It was very similar indeed but I don't think it was the same engine...
reganlives
25-06-2020, 02:37 AM #22
25-06-2020, 03:18 AM
reganlives You mean the black one that was for sale? It was very similar indeed but I don't think it was the same engine...
You mean more than one idiot fitted their charger the wrong way up?
Sent from my Nexus 4 using Tapatalk 2
25-06-2020, 03:18 AM #23
reganlives
25-06-2020, 03:22 AM
Stoney You mean more than one idiot fitted their charger the wrong way up?
By the looks of it yes...!:lol:
reganlives
25-06-2020, 03:22 AM #24
Mr quinn
25-06-2020, 11:03 AM
Well the good news is its all in and running, I posted on here a few weeks ago about a problem with it cutting out wjen ive put my foot down, usually on the dual carriageway or after hard acceleration and coming off the gas quickly, ive tried lots of things to cure it, its running a mini bypass valve and with just that it cuts out alot, with the bypass valve and a recirc bov its loads better so ive tried running the bypass valve, the recirc bov and a hks ssqv to see if it cures it and still hasn't Sad
The only thing i can think of trying next is trying to get the clutch on the supercharger operational again Confused
And im assuming its not going into limp mode due to fuel cut as its got the aem piggy back which has been mapped so surely this would remove the need for a fcd?
Any suggestions what to try next would be appreciated Smile
Thanks
Mr quinn
25-06-2020, 11:03 AM #25
Thanks
reganlives
25-06-2020, 11:11 AM
Have you had the aem piggy back mapped yourself mate or is it running a base map of some sort? If so then that may be the cause.
reganlives
25-06-2020, 11:11 AM #26
Mr quinn
25-06-2020, 11:16 AM
No not myself, it was mapped before I got it at thor, anyone know a good place to get it done near suffolk?
Mr quinn
25-06-2020, 11:16 AM #27
Jon
26-06-2020, 09:22 AM
just for your info, im running a mini cooper bypass and ssqv, but with a 130mm pulley and patricks black box and mines running fine
i'd be looking at the ECU, and getting it mapped
Jon
26-06-2020, 09:22 AM #28
26-06-2020, 09:41 AM
Mr quinn No not myself, it was mapped before I got it at thor, anyone know a good place to get it done near suffolk?
The fault code should give an idea as to the cause. Could need mapping again or just the voltage clamp that acts as an FCD is set wrong, check that first if possible.
26-06-2020, 09:41 AM #29
Views 346
13-07-2023, 10:07 AM
Views 1,774
05-07-2023, 05:08 AM
Last Post by damtrx
Views 828
17-04-2023, 03:51 AM
Views 1,424
05-04-2023, 03:19 AM
Last Post by damtrx
Views 768
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 306
29-11-2022, 03:38 AM
Last Post by phaebo
Views 402
30-04-2022, 06:27 AM
Views 606
27-04-2022, 12:45 PM
Last Post by oedipus
Views 698
19-06-2021, 12:50 PM
