JapCarForum Cars, Cars, Cars! Wheels & Tyres urgent advice plz!!
urgent advice plz!!
urgent advice plz!!
iLLzLex
29-12-2016, 11:50 PM
For real? Brand new? All 4?
iLLzLex
29-12-2016, 11:50 PM #21
30-12-2016, 03:43 AM
Why are you getting a brake upgrade ? If you want the brakes discs to look nicer (e.g. grooved etc) then fine. Don't get Yellow Stuff pads though, they're for racing so won't be so good on the street.
I think your money would be *much* better spent on a set of upgraded ARBs, which will vastly improve the handling of your car and therefore the enjoyment.
30-12-2016, 03:43 AM #22
iLLzLex
30-12-2016, 03:48 AM
steviewevie Why are you getting a brake upgrade ? If you want the brakes discs to look nicer (e.g. grooved etc) then fine. Don't get Yellow Stuff pads though, they're for racing so won't be so good on the street.
too late..just submitted the order..and yeah i think it would look awesome with grooved drilled disks...on the website it said that yellowstuff can be used for track and road use so we shall see Smile should be getting delivery tomorrow and fitment on saturday..should look the dogs nuts with new alloys :thumbup1:
iLLzLex
30-12-2016, 03:48 AM #23
iLLzLex
30-12-2016, 03:50 AM
http://www.potn.co.uk/p1187390.htm
apparently u dont need to punish them it says they bite well from cold... ill submit feedback after saturday Smile
iLLzLex
30-12-2016, 03:50 AM #24
30-12-2016, 03:54 AM
I think the brakes act differently as if you use the Yellows the brakes need to get much hot to be as effective as green's
But i might stand to be corrected...
30-12-2016, 03:54 AM #25
30-12-2016, 03:55 AM
Marsdendean If its for track, won;t they require more punishment to get them to work 100%, or does it just mean if you punish them they won't fade as quickly??
It'll be both I think.
30-12-2016, 03:55 AM #26
iLLzLex
30-12-2016, 03:56 AM
Lexusboy I think the brakes act differently as if you use the Yellows the brakes need to get much hot to be as effective as green's
please dont scare me ...ill be extremely peed off if they are not working...but im sure if the website says road/track then they should be fine? :blink:
iLLzLex
30-12-2016, 03:56 AM #27
30-12-2016, 04:05 AM
They'll probably be fine under normal use, but they'll probably have a higher optimum operating temperature so hard braking without them heated up will probably be less effective than the greens which are probably developed with purely road use in mind.
30-12-2016, 04:05 AM #28
iLLzLex
30-12-2016, 04:12 AM
cant wait for fittment...should look NUTS!!!
iLLzLex
30-12-2016, 04:12 AM #29
30-12-2016, 05:00 AM
The yellow pads will hold better temps and grip at higher running speeds like on track or fast street use, if they get too hot the pads glaze over and reduce the breaking efficiency, cold pads always work better than hot hence the reason for vented/grooved or drilled discs, the holes are there to help cool them down and not for show, and usually de-glaze the pad under heavy use giving a good bite most of the time, So the yellow ones are good for fast street or track, but for everyday type of driving your better off going for normal pads?
I had the Mintex Extreme pads on my IS200 SC, and at high speed they were great, but normal driving i found them not as good as the standard pads that were originally fitted? :biggrin:
30-12-2016, 05:00 AM #30
 9 Guest(s)
 9 Guest(s)
Views 1,704
17-09-2018, 11:36 PM
Last Post by lebon
Views 736
10-09-2018, 10:37 AM
Last Post by mpls24
Views 952
05-02-2018, 03:07 PM
Last Post by BOOSST
