JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! How to.... disassemble the TTE-charger on a Lexus IS200
Pages (3): Previous 1 2 3
12-07-2018, 12:25 AM
Rob/ any one in the know my work uses 75/90 synthetic gear oil is this ok?
12-07-2018, 12:25 AM #21
12-07-2018, 12:37 AM
I've not got the experience of Rob but pretty sure the stock S/C oil is 75/90. The AW11 MR2 has an Eaton roots-type supercharger as well and the oil for that is 75/90. It's super expensive from Toyota but there's a Jag part number which is just relabelled Eaton s/c oil and is MUCH cheaper: JLM12290
As mentioned it's only for splash lubrication. You probably wouldn't want to use anything with seal swelling agents in it either.
Edited 23-08-2011, 10:14 AM by toxo.
12-07-2018, 12:37 AM #22
12-07-2018, 02:20 AM
Obviously its a case of horses for courses, but for what its worth I use Royal Purple Syncromax on my charger.
12-07-2018, 02:20 AM #23
12-07-2018, 03:32 PM
right a sealer question now...
whats better loctite 518 gasket maker
or
loctite 510?
also do you put sealer round the inlet and exhaust part of the charger?(the parts held on with allen key bolts)
12-07-2018, 03:32 PM #24
or
loctite 510?
rob
19-07-2018, 10:57 AM
i use loctite 510 - the pink stuff. but you MUST let it cure before putting the oil in - wait at least 24hrs, if u try earlier you will end up with a leak as i found out
rob
19-07-2018, 10:57 AM #25
 4 Guest(s)
 4 Guest(s)
Views 179
13-12-2022, 05:57 AM
Replies 46
Views 7,226
16-03-2022, 12:02 AM
Last Post by Emissary
Views 802
10-09-2021, 01:07 PM
Replies 25
Views 4,562
18-08-2019, 06:32 AM
Last Post by Johny47
Views 518
24-01-2019, 02:06 PM
Views 1,993
03-10-2018, 08:33 AM
Views 818
04-09-2018, 10:45 AM
Replies 41
Views 3,035
09-04-2018, 11:19 PM
Last Post by IanS200
Views 799
23-01-2018, 07:18 AM
Last Post by Jambo
