Lexus IS200 Amp Bypass Cable fitting with pic's?
have they been thoughtful and added in a high level sub output?
I have no idea about those extra bits, they sound like they're optional and won't need connecting if you don't have a sub.
Mr Bandit, what year was your motor?
Bandit 2000 V plate mate,just found my lead too and my sat nav conversion box
Have to say this walk through is spot on, i had it out, connected to the bypass lead and refitted in under 30 mins, and that was including me being fussy deciding which way i wanted the bypass lead to go and where to put the iso connector (put it in the kick box, as fitting the head unit brain in the boot so want to make sure i have as much cable as possible at the other end) not a single cut/scrape on my hands, which i can say for sure would not have been the case if i didnt have this to follow, thanks Mr B, top man:thumbup1::thumbup1::thumbup1::thumbup1:
