JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Bypass cable and now lacking bass.
Pages (3): 1 2 3 Next
Predator
21-09-2019, 07:35 AM
Hi,
Since I've installed the bypass cable and new 50w head unit, I don't seem to get much bass.
Does the SE is200 have a bass box installed?
The head unit has a separate sub woofer cable. Does this need to be added directly to the systems bass box (if it has a separate one)?
Thanks,
John
Predator
21-09-2019, 07:35 AM #1
Hi,
Thanks,
John
21-09-2019, 07:41 AM
It doesn't have a separate sub/bass box.
Is it possible to turn the sub pre-out off on your head unit, or to make the normal outputs 'full-range' as it may have a built in crossover trying to send the lower frequency signals to the subwoofer output.
21-09-2019, 07:41 AM #2
Predator
21-09-2019, 07:49 AM
I have looked through the options but all I could see was balance, fade, treble, mid and bass.
I'll have a good look later and check I can hear sound from all the speakers. Is it a 6 speaker plus 2 tweeters setup?
Thanks,
John
Predator
21-09-2019, 07:49 AM #3
Thanks,
John
21-09-2019, 07:58 AM
Lexus refer to it as either 6 or 8 speaker (don't know which one the SE has) but they include the tweeters in that. As far as I know, the difference between 6 or 8 is simply whether the rear speakers are 1-way or 2-way, but I might be wrong there.
What make stereo is it?
21-09-2019, 07:58 AM #4
Predator
21-09-2019, 09:00 AM
The Se definitely has the better sound system.
Do 2-way speakers carry more bass?
John
Predator
21-09-2019, 09:00 AM #5
John
No, they are capable of more accurately reproducing a range of frequencies due to having 2 cones and 2 coils.
21-09-2019, 09:00 AM #6
Predator
21-09-2019, 09:02 AM
Ps, I have no idea what 2-way speakers are or what they do.
I've never really been in to sound systems, as I've always preferred the engine note or exhaust (classy, not big bore) but the is200 is a bit too toned down for that, lol.
John
Predator
21-09-2019, 09:02 AM #7
John
Predator
21-09-2019, 09:03 AM
toxo No, they are capable of more accurately reproducing a range of frequencies due to having 2 cones and 2 coils.
Ok, so nicer sounding speakers Smile
Thanks,
John
Predator
21-09-2019, 09:03 AM #8
Thanks,
John
21-09-2019, 09:05 AM
Does this help? Smile
[Image: is200Speakers.jpg]
You can see the 2 versions of the rear speakers at the bottom, w/6sp only has 1 cone, w/8sp is like the 6sp one but with another housing on top of it with basically a tweeter mounted over the normal speaker.
Edited 01-11-2012, 06:39 PM by toxo.
21-09-2019, 09:05 AM #9
Predator
21-09-2019, 09:13 AM
Got ya. I definitely have the 8 speaker setup.
I'm just not sure how to get the best best sound.
I'm going to play around With the fade button and check all the speakers are active.
Cheers,
John
Predator
21-09-2019, 09:13 AM #10
Cheers,
John
Views 683
02-12-2020, 01:19 PM
Replies 88
Views 19,647
26-01-2020, 06:18 AM
Last Post by iceman
Views 582
26-01-2020, 01:12 AM
Last Post by Colin G
Views 2,424
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 655
02-04-2019, 08:16 AM
Last Post by James S
Views 1,043
11-02-2019, 09:50 AM
Last Post by northernmonkey
Replies 22
Views 2,700
06-11-2018, 11:29 AM
