JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security IS200 Using Amp Bypass Lead-Lost power to pop up sat nav
Pages (5): 1 2 3 4 5 Next
roadrunner
28-05-2018, 09:19 AM
Hi All,
Recently became an outlaw and need some help. I own a Lexus IS200 Sport 02 plate. Fitted a new aftermarket double din useing the amp bypass lead. All works well but lost power to my pop up sat nav. I went for advise to an auto electrician but he seemed to shy away as soon as i mentioned it was an IS200, he said he had problems once before and never used the bypass lead but used a standard toyota ISO,he also mentioned a 3rd plug with 3 wires at the back of the factory double din and said he singled out one of those wires and connected a wire with an in-line bulb which swithed the sat nav on but he said that you had to have the wire with the bulb in an accessible place incase of having to change the bulb. To be honest, this method sounds a bit risky to me. So i thought i would seek further advice from outlaw. I do have wiring diagrams for the sat nav and double din. I just need someone to kindly simplify a way round this so that i can still use my sat nav aswell as my new aftermarket Double Din. I am myself a motor mechanic. Just need to know the best way round this and what colour wires connect/disconnect or tap into. Someone must of come accross this problem. Much Appreciated RobSad
roadrunner
28-05-2018, 09:19 AM #1
Hi All,
28-05-2018, 10:34 AM
The Sat nav "talks" to the OEM Head unit, the easiest way is to find someone that makes a "Dongle" to get around this issue, there was someone but I just can't remember his name lol.
Or extend the OEM wires into the boot and plug the OEM head unit in there.
28-05-2018, 10:34 AM #2
28-05-2018, 10:57 AM
Fargo makes the cables so you dont loose the sound but not sure how to contact him these days.
Unless someone else knows how to make a fix? surely cant be too hard
28-05-2018, 10:57 AM #3
roadrunner
28-05-2018, 11:06 AM
Thanx a million for your reply, will do some investigating on the dongle but i will sack the idea of cutting the oem plugs to extend the loom to the boot and i don't like the idea of the oem dd sat in the boot trembling when i let rip haha
roadrunner
28-05-2018, 11:06 AM #4
roadrunner
28-05-2018, 11:22 AM
Cheers Fargo, I agree, There must be an easy fix. Just knowing how. Auto electrics is a mindfield and i won't take chances on impulse as i have seen too much damage done to ecu's melted fuseboxes, dash fires etc. Thanks again, hopefully someone will know an easy fix.
roadrunner
28-05-2018, 11:22 AM #5
speedfreek
28-05-2018, 01:39 PM
I would love a Fargo cable too, tried to contact him to no avail Sad
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
28-05-2018, 01:39 PM #6
[/SIZE]
(Current project)
28-05-2018, 05:04 PM
He might be on LOC more often try getting him on that
28-05-2018, 05:04 PM #7
29-05-2018, 02:41 AM
Try this mate CLICK ME? I still have one of Fargo's original boxes in mine and it does work very well :thumbup1:
29-05-2018, 02:41 AM #8
29-05-2018, 02:47 AM
its only a couple of diodes and resistors you can make the box your self guys
29-05-2018, 02:47 AM #9
29-05-2018, 02:51 AM
think the diagrams and parts required are in that link i posted too :thumbup1:
29-05-2018, 02:51 AM #10
Views 661
30-09-2022, 11:42 AM
Views 677
02-12-2020, 01:19 PM
Replies 88
Views 19,637
26-01-2020, 06:18 AM
Last Post by iceman
Replies 22
Views 1,513
05-10-2019, 03:45 AM
Last Post by Predator
Views 2,419
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 706
28-09-2019, 08:22 AM
