JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Smoking headlights
Smoking headlights
Smoking headlights
Pages (3): Previous 1 2 3
08-04-2017, 02:39 PM
theirs no screws on the headlight either mate....... well their is but you dont remove them!!the lens is bonded on and only bonded...
08-04-2017, 02:39 PM #21
09-04-2017, 05:08 PM
The headlights are the same as the fogs flat head screwdriver under the clips to open it up.
Its easy I think everyone has this feeling at first.
Mine only steams up on the corners if I jet wash it but don't do that very often
09-04-2017, 05:08 PM #22
10-04-2017, 08:01 PM
The best thing to use for sealing the light units is Sikaflex sealant, silicone needs to be rubbed in around the edges to create a good seal or you end up with gaps when it dries, which lets air/water in so the lights fog up??
The Sikaflex one used on lighting is the grey version, it stays flexible and elastic and its also weather resistant, Like this one CLICK ME? :thumbup1:
10-04-2017, 08:01 PM #23
11-04-2017, 11:04 PM
I would have thought a decent sized bead around the lens would spread enough when you press the lens together followed by wiping off any excess that comes out without having to spread it with fingers....or is that not the case?
11-04-2017, 11:04 PM #24
Ally
19-07-2017, 11:29 AM
I removed the black tinting spray from my fog lights today. One of them not only has condensation, but about 50ml of water swishing about at the bottom:cursing:. Looks like i'm going to have to heat the oven up before JAE. Unless the tinting film that i'm just about to order covers everything up:blink:. Somehow i don't think i'll be that lucky..........
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
19-07-2017, 11:29 AM #25
19-07-2017, 06:46 PM
Ally I removed the black tinting spray from my fog lights today. One of them not only has condensation, but about 50ml of water swishing about at the bottom:cursing:. Looks like i'm going to have to heat the oven up before JAE. Unless the tinting film that i'm just about to order covers everything up:blink:. Somehow i don't think i'll be that lucky..........
Put a goldfish in there!! :tongue_smilie::laugh:
19-07-2017, 06:46 PM #26
Ally
19-07-2017, 10:52 PM
SHAHZ Put a goldfish in there!! :tongue_smilie::laugh:
A JDM yellow one :wink:
Ally
19-07-2017, 10:52 PM #27
Phil01
21-07-2017, 02:47 PM
But it will then look like he has tango'd them:laugh:
Phil01
21-07-2017, 02:47 PM #28
 3 Guest(s)
 3 Guest(s)
Views 251
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Replies 22
Views 1,177
09-07-2020, 04:04 PM
Last Post by powerdbyis
Views 1,011
29-03-2019, 10:58 AM
Views 664
13-10-2018, 02:54 PM
Views 900
14-04-2018, 11:00 PM
Last Post by James S
Replies 18
Views 1,168
03-02-2018, 03:27 PM
Last Post by DTD
Views 1,051
22-11-2017, 04:36 PM
Last Post by D6NGR..
Replies 40
Views 2,037
03-09-2016, 09:10 AM
