JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications is200 diy supercharger info
beamstezza
22-07-2020, 07:35 PM
#31
Uodate.
So got my genuine tte cradle and then went and bought a a whole 98 slk 230 kompressor witch has the right charger and when I had a look and some other parts its looks like it has the same intercooler as tte used but could possibly be bigger also the snorkel for trottle body is almost the exact same as tte one. Copy cats LOL
Now here is my question iv looked at the pully on the merc and it looks like the centre goes in a lot and I'm not sure if it will fit as I haven't taking it off yet.
Could someone please show me a picture of there pulley to see difference
Thanks.
beamstezza
22-07-2020, 07:35 PM #31
Uodate.
Thanks.
bigdave1701
23-07-2020, 12:01 AM
#32
Does it look easy to do mate
bigdave1701
23-07-2020, 12:01 AM #32
beamstezza
23-07-2020, 06:00 AM
#33
bigdave1701 Does it look easy to do mate
No very straight forward I have the charger out witch was a the hardest part there's not much room to remove it.
beamstezza
23-07-2020, 06:00 AM #33
bigdave1701
11-08-2020, 09:53 AM
#34
Serviced my charger today guys was cool and pretty easy to do changed the rear bearings and the oil sounded much smoother posting a few pics
[Image: image%20%287%29.jpeg]
[Image: image%20%282%29.jpeg]
[Image: image%20%283%29.jpeg]
[Image: image%20%284%29.jpeg]
[Image: image%20%285%29.jpeg]
https://www.dropbox.com/s/gz8mnhko8hdyi5...86%29.jpeg
bigdave1701
11-08-2020, 09:53 AM #34
bigdave1701
11-08-2020, 09:55 AM
#35
Happy i did it as there was so little oil inside
bigdave1701
11-08-2020, 09:55 AM #35
phaebo
11-08-2020, 10:00 AM
#36
Are you sure that the oil seals arent leaking? My old supercharger was also leaking oil through the oil seals. Those are behind the rotorbearings.
phaebo
11-08-2020, 10:00 AM #36
bigdave1701
11-08-2020, 10:03 AM
#37
could be a good call wish i had checked its pretty easy to do will keep a eye on it didnt see any signs of leaks
bigdave1701
11-08-2020, 10:03 AM #37
phaebo
11-08-2020, 10:06 AM
#38
Well i explored mine was leaking because it started to mAke more and more noise. Also when i installed my blow off valve it was squirting oil out of the blow off valve. There wasnt any oil left in the charger.
phaebo
11-08-2020, 10:06 AM #38
bigdave1701
11-08-2020, 10:10 AM
#39
Guess the vacuum wouldn't help even the smallest leak i have the parts to change bit 2 but was in a rush.
bigdave1701
11-08-2020, 10:10 AM #39
20-09-2020, 11:04 AM
#40
Bump. Moley, are you still thinking of making cradles this winter?
20-09-2020, 11:04 AM #40
Views 1,767
05-07-2023, 05:08 AM
Last Post by damtrx
Views 1,898
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 824
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 827
17-04-2023, 03:51 AM
Views 513
06-04-2023, 02:00 AM
Views 1,423
05-04-2023, 03:19 AM
Last Post by damtrx
Views 742
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Replies 24
Views 1,214
12-01-2023, 11:53 AM
