JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lexus IS200 Reprogramming Key Fob
Pages (4): Previous 1 2 3 4
PETEHAMASAKI
09-08-2019, 12:10 PM
#31
will the Remote Programming set-up the rear boots door pop up?
PETEHAMASAKI
09-08-2019, 12:10 PM #31
09-08-2019, 12:15 PM
#32
If memory serves yes does yours not pop open from the remote
09-08-2019, 12:15 PM #32
PETEHAMASAKI
09-08-2019, 03:21 PM
#33
Rabster If memory serves yes does yours not pop open from the remote
it's a 2001 sport... had 3 button key remote, it's work fine with the central locking but just the boots not pop up (press and hold boot button) won't work.
some say it need to be reprogrammed for the key remote to work
not really sure if it's the remote or the boot lock mechanismConfusedad:
PETEHAMASAKI
09-08-2019, 03:21 PM #33
PETEHAMASAKI
28-08-2019, 05:28 AM
#34
hi
does anyone know this item really works?:Sulk:
£bay Item number: 120960904434
many thanks
PETEHAMASAKI
28-08-2019, 05:28 AM #34
hi
many thanks
jasons
28-08-2019, 06:58 AM
#35
PETEHAMASAKI hi
many thanks
Downside is that the instructions are in pretty poor 'Engrish'..
Upside is that it's only £20 so no great loss if it doesnt work..
J
jasons
28-08-2019, 06:58 AM #35
PETEHAMASAKI hi
many thanks
J
cjoseph
04-08-2021, 04:34 AM
#36
Fry-Up Having tried to program my 2 new keys without success, I googled, specifically IS300 key programming and found it varied very slightly from the guides already here, I shall post them as using the following guides instead, I successfully managed to do my keys Big Grin (for a total cost of £40, that was both blank blades (a 2 button and a 3 button, getting them cut, and both transponders)
Key Programming (so the key starts the car)
1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on the brake one time.
Note: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will be come on and start blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming (so the buttons operate the locks)
1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove. Do not turn it on.
3. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock) YOU WILL NOTICE THE SECURITY LED FLASHES QUICKLY NOW
4. Close and open drivers door.
5. Using the electric lock switch. Lock and unlock 5 times again.(Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
6. Put key into ignition. Turn to "ON", turn off and remove.
7. You will see the door locks cycle by themselves.
If the door locks do not cycle (lock, unlock) by themselves then the car isn't in programming mode and you must start over.
8. On the new remote. Press and hold Lock and Unlock button at the same time for no more than 2 seconds.
9. On the new remote, press the Lock button for no more than 1 second.
AT THIS POINT. The locks should cycle by themselves ONE time. This means the procedure was accepted.
IF the locks cycle TWICE it has failed. Don't start over just yet:
As long as the car is still in programming mode you can keep trying step 8 and 9 until you complete the programming. If you wait too long and the car exits the programming mode then you must start over.
(I did have to repeat steps 8 & 9 a couple of times leading me to believe this guide is very slightly inaccurate with regards the new fob presses, but third time lucky)
After you get the remote to program then continue on with step 10.
10) Close and open door to end programming procedure.
ENJOY
Thanks a million worked first time on my is200 😃
cjoseph
04-08-2021, 04:34 AM #36
ENJOY
Views 413
13-12-2023, 02:06 PM
Views 547
09-11-2023, 03:46 AM
Last Post by Dinho
Views 926
06-11-2022, 01:49 AM
Views 3,045
02-11-2022, 10:55 AM
Views 371
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,601
23-02-2022, 01:20 PM
Views 416
18-10-2021, 02:04 AM
Views 364
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 577
03-09-2021, 11:04 AM
Views 535
29-08-2021, 09:59 AM
