JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza BOOT Control
BOOT Control
BOOT Control
jomo
18-06-2017, 11:52 AM
#31
ormi you have to buy special ones that only come in pairs and they are expensive..
also if you let the gass out you can let out too much then you have to send them away for a refill
What makes them "special"?
Wont any the right size do the job?
And how much is expensive?
Do you have one fitted Ormi?
jomo
18-06-2017, 11:52 AM #31
18-06-2017, 12:47 PM
#32
no the right size wont mate (the size is 440mm) if you get a normal 440 one theirs no way of adjusting the pressure and they are too powerfull..
the correct ones are approx 50-60 plus p&p i think and a refill if you get it wrong is approx 20 plus p&p..
18-06-2017, 12:47 PM #32
18-06-2017, 12:49 PM
#33
ps i did fit one ok more than one(i fitted ten diff types)and they all pushed the boot out of alighn when closed!!
18-06-2017, 12:49 PM #33
18-06-2017, 01:07 PM
#34
seems ive started something here lol
so im not the only one with a **** boot
18-06-2017, 01:07 PM #34
20-06-2017, 09:46 PM
#35
I have boot strut on the SC so i wonder if these would work the same.
These have to lift up to allow the roof to fold away.
Think these are also around £60 each
20-06-2017, 09:46 PM #35
21-06-2017, 12:04 AM
#36
But Ian, doesn't yours need the strut to hold the boot up?
21-06-2017, 12:04 AM #36
21-06-2017, 01:04 AM
#37
Dark Samurai But Ian, doesn't yours need the strut to hold the boot up?
Yes my car has no choice, as it need to put the roof away remotely
IS200 driver want to push their remotes on their keys and their boot lifts & raises fully open.
What is different between between what the IS200 and my car, both cars need the boot to be opened and lifted into position.
The struts that people want on their IS200 will hold the boot up so i dont see the difference.
21-06-2017, 01:04 AM #37
Fozzy
21-06-2017, 01:13 AM
#38
but arnt yours hydraulic actuators rather than simple struts, as it closes the boot after the roof is down, or does it have a 2 way hinge system?
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
21-06-2017, 01:13 AM #38
#39
I wonder if someone could find the mechanism on an SC430 at a breakers and fit it to an IS200 to make the boot open and close remotely......where's Rabs, sounds like a job for him Smile
21-06-2017, 01:13 AM #39
21-06-2017, 01:21 AM
#40
I think it must have a two way hinge system.
The boot opens different ways depending if your opening the boot or opening the roof.
21-06-2017, 01:21 AM #40
Views 383
27-03-2022, 11:16 PM
Views 1,334
21-07-2021, 11:53 PM
Views 207
23-03-2020, 11:52 AM
Views 859
02-09-2018, 12:30 PM
Last Post by dodgydave
Views 570
23-05-2018, 10:09 AM
Last Post by Dinho
Views 751
01-04-2018, 10:32 AM
Last Post by jasons
Views 1,106
13-01-2018, 04:17 PM
Last Post by hawk77ojc
Views 741
03-11-2017, 10:16 PM
