JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Is300/200/altezza owners can you do me a favor
Fry-Up
22-01-2019, 09:04 PM
#31
No i'm in agreement with Moley, my 2000 IS2 one press locked and alarmed, indicators flashed once, 2nd press deadlocked (double locked, however you understand it) and de-activates sensors and indicators flash a further 5 times,
my 2002 IS3 is the same but second press indicators only flash once more not 5 times more
Fry-Up
22-01-2019, 09:04 PM #31
22-01-2019, 10:02 PM
#32
My 02 IS200 doesn't flash at all on the second press, and the manual said it did the deadlocks but I don't remember seeing anything about it not arming the alarm...
If I can be bothered in the morning I'll pull out the manual and check what it says Smile
22-01-2019, 10:02 PM #32
dodgydave
23-01-2019, 06:24 AM
#33
The confusion here is over the age of the vehicle.
On the earlier models that double lock automatically a second press on the lock button deactivates the interior sensor for the alarm, for if you want to leave an animal in the car or something. On the later models where you have to press the lock button a second time to double lock you can still deactivate the interior sensor using the method that cptthunder said above. As I said earlier I'm not sure when this was changed I think it was probably around 2001.
dodgydave
23-01-2019, 06:24 AM #33
23-01-2019, 06:34 AM
#34
Mines a 2000 v plate, one press locks the car and 2nd press deactivates the interior sensor? use it quite a lot with the kids and dog :thumbup1:
As Dave says above in 2001+ they used the new system for some reason? from reading in the past some of the 1999-2000 models didn't actually have the deadlock system fitted?
23-01-2019, 06:34 AM #34
23-01-2019, 06:37 AM
#35
might have to have a read of the old manual as mines a 2001 Y and not sure what is what
23-01-2019, 06:37 AM #35
cptthunder
23-01-2019, 07:23 AM
#36
I think we have derailed this slightly from what Rab wanted so go get back on track
car year: 2004
Car model: is200
drivers door lock status: B
cptthunder
23-01-2019, 07:23 AM #36
car year: 2004
Car model: is200
dodgydave
24-01-2019, 05:25 PM
#37
Just to confuse everyone even more.
I did a bit more testing on mine at the week end. just to check hat everything is as it should be now.
As you may of read earlier in this thread mine wouldn't unlock by using the key in the drivers door. It's now been back to the bodyshop and they have fixed it.
Now I can lock and unlock the drivers door by using the key in lock but If I lock the car (and activate the alarm) by pressing the lock button on the remote then unlock using the key in the door it still doesn't actually unlock the car.
Now after locking using the remote the alarm is armed after about 30 seconds, if you watch the red security LED on the dash it is solid and then flashes after 30 seconds. If I lock using remote and then unlock using the key within this 30 seconds all is fine the door unlocks and the alarm doesn't sound. BUT if I lock using the remote, wait 30 seconds until the alarm is activated (Red LED flashing), then unlock using the key the alarm goes off and the door remains locked.
What worries me is what happens if your battery runs flat in your remote or it gets damaged??? It would appear that you can't get in at all!!!
Incidentally there isn't any instructions in the owners manual on what to do if your remote doesn't work.
Perhaps someone could try this on their car to see if this is correct.
dodgydave
24-01-2019, 05:25 PM #37
24-01-2019, 06:51 PM
#38
I'm really confused by that, is there some electronics involved with the door lock then if it unlocks with the key when the alarm is off but doesn't when the alarm is on?
Also does the alarm go off just by turning the key in the lock? That's not supposed to happen, the alarm on my car only goes off when you open the door, not when you unlock it.
There's something really weird going on with your car.......... :confused:
The key should open the door, and the alarm stops a short while after you start the engine. That is the backup if the key remote dies - was the car always like this or only after the bodywork?
Edited 07-03-2011, 10:39 PM by parthiban.
24-01-2019, 06:51 PM #38
Fry-Up
24-01-2019, 09:17 PM
#39
Are we any closer to finding out the use for this info...?
Fry-Up
24-01-2019, 09:17 PM #39
25-01-2019, 07:53 AM
#40
Fry-Up Are we any closer to finding out the use for this info...?
Yep as above Rabs is trying to figure out the way the standard alarm system works on different years so the proximity access system can be integrated :thumbup:
25-01-2019, 07:53 AM #40
Views 287
07-02-2024, 06:24 AM
Views 438
15-09-2021, 08:11 PM
Views 435
16-04-2021, 04:40 AM
Last Post by CammyGrieve
Views 1,090
10-05-2019, 06:24 PM
Views 526
28-02-2019, 08:21 AM
Last Post by bash6673
Views 843
15-02-2019, 10:36 PM
Last Post by LEX11S
Replies 18
Views 1,434
03-02-2019, 09:16 PM
Last Post by DTD
Views 1,172
30-09-2018, 12:26 PM
Views 1,205
01-01-2018, 10:51 AM
Last Post by Asi
