JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza supercharged is200 you might want to look at this
12-07-2018, 11:35 AM
#31
ormi what oil have you got matey?what did you do to fix yours?
The oil Rabster used was the Castol Driveline syntrax universal, 75W-90 :biggrin:
Not done much to it mate, but when i had it off to polish it, i polished the intake port inside, just to get rid off some of the rough edges? and cleaned out the charger inside which surprisingly had loads of black gunk inside, just used a good cleaner to spray inside and then rinsed it out making it look like new again? runs so much smoother and made quite a bit of difference to it for some reason? :thumbup:
12-07-2018, 11:35 AM #31
12-07-2018, 12:08 PM
#32
so did you split the charger?did you use a file follower by paper to polish the intake?
Edited 23-08-2011, 09:43 PM by ormi.
12-07-2018, 12:08 PM #32
12-07-2018, 08:42 PM
#33
ormi so did you split the charger?did you use a file follower by paper to polish the intake?
Used a fine file mate, fitted to a rechargeable drill, took the intake snout off and smoothed it off, was quite lumpy in there and i was bored more than anything, so thought i'd tidy it up? :laugh::laugh: then just used a fine wet and dry to clean it up? :biggrin:
12-07-2018, 08:42 PM #33
12-07-2018, 10:01 PM
#34
Do you use sealer to put it back on?
12-07-2018, 10:01 PM #34
12-07-2018, 11:04 PM
#35
ormi Do you use sealer to put it back on?
When I took mine apart, there was certainly some form of sealant used before.
12-07-2018, 11:04 PM #35
Talisker
17-07-2018, 02:47 AM
#36
So Ormi,
How are you going to block the silencer holes? Are you going to weld plates over them or use some other method?
Strange how everyone is reconditioning their chargers, I did mine about a month ago. I ported the intake and outlet snouts and cleaned all the gunk out of the inside.
I may well have a go at porting the triangular outlet if i can get hold of second supercharger to play with.
I've gone over the the Greddy Boost Cut Controller instead of the HKS FCD it works in a better way to the FCD. If you can get hold of one I recommend it to any supercharger owner.
Talisker
17-07-2018, 02:47 AM #36
So Ormi,
17-07-2018, 06:46 AM
#37
Talisker I've gone over the the Greddy Boost Cut Controller instead of the HKS FCD it works in a better way to the FCD. If you can get hold of one I recommend it to any supercharger owner.
What I've been telling people for years mate.
17-07-2018, 06:46 AM #37
17-07-2018, 07:25 AM
#38
im just going to leave the silencer holes mate and just open the v up...
the only reason i done mine was i didnt know when the oil was changed and i wanted to check the rotors..
what diff will running the greddy do over running the hks
17-07-2018, 07:25 AM #38
17-07-2018, 07:39 AM
#39
The BCC is almost exactly like the orignal black box that clamps the voltage once it goes over a set figure, rather than the FCD that "lies" to the ecu right through the range when its not needed, only once the MAP pressure gets towards the boost cut.
17-07-2018, 07:39 AM #39
17-07-2018, 07:47 AM
#40
aaaaa i might look in to that then
17-07-2018, 07:47 AM #40
Views 341
13-12-2023, 02:06 PM
Views 478
09-11-2023, 03:46 AM
Last Post by Dinho
Views 725
06-11-2022, 01:49 AM
Views 1,380
02-11-2022, 10:55 AM
Views 314
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,213
23-02-2022, 01:20 PM
Views 359
18-10-2021, 02:04 AM
Views 477
03-09-2021, 11:04 AM
Views 494
29-08-2021, 09:59 AM
Replies 35
Views 7,776
04-08-2021, 04:34 AM
Last Post by cjoseph
