Pages (51): Previous 1 2 3 4 5 651 Next
04-10-2019, 06:11 PM
#31
Hang on, are you turning a vvti engine in to a non vvti engine?
04-10-2019, 06:11 PM #31
04-10-2019, 06:19 PM
#32
No. The VVTi engine is only available with the sump right at the front and that won't fit in the rx7 because the steering rack and subframe are in the way. You can bolt on the sump & oil pan (and pickup, and baffle and so on) from the earlier non-VVTi engine.
04-10-2019, 06:19 PM #32
04-10-2019, 06:22 PM
#33
Have a read of this post I wrote on my website for more info about sumps:
http://www.project-ruze.co.uk/?p=62
04-10-2019, 06:22 PM #33
reco2k
04-10-2019, 06:46 PM
#34
toxo No. The VVTi engine is only available with the sump right at the front and that won't fit in the rx7 because the steering rack and subframe are in the way. You can bolt on the sump & oil pan (and pickup, and baffle and so on) from the earlier non-VVTi engine.
I did a lot of research ino the rx7 conversion and almost did it, there are a few ways to make it fit, the easiest is as you say take the sump etc from a soarer engine, enlarge 4 of the holes and then swap it onto the vvti engine. then if you take out the rear of the subframe it will go in ok and it can be mounted to the chassis rails
reco2k
04-10-2019, 06:46 PM #34
04-10-2019, 07:13 PM
#35
Well Toxo when will it be up and running ?
04-10-2019, 07:13 PM #35
04-10-2019, 07:17 PM
#36
Some time in 2013 I reckon!
04-10-2019, 07:17 PM #36
04-10-2019, 07:26 PM
#37
I thought they were fast enough as standard ? Am I wrong ?
So why are you putting in a V8 apart from POWER !!!! LOL
04-10-2019, 07:26 PM #37
04-10-2019, 07:29 PM
#38
They are fit cars and I like V8s.
04-10-2019, 07:29 PM #38
04-10-2019, 07:33 PM
#39
good answer Big GriniscoStu:
04-10-2019, 07:33 PM #39
05-10-2019, 04:43 PM
#40
I've started putting updates on a website I set up ages ago, a kind of project blog.
See http://www.project-ruze.co.uk/ for more info. Oh, you can 'like' it on facebook too if you're that way inclined.
05-10-2019, 04:43 PM #40
Views 1,852
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 1,453
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 730
21-05-2024, 04:24 AM
Replies 362
Views 31,908
06-08-2023, 02:50 PM
Last Post by john wan
Replies 1,318
Views 96,145
05-06-2023, 02:12 PM
Last Post by sarah0
Views 2,817
03-03-2023, 03:41 PM
Views 1,817
16-11-2022, 05:59 PM
Views 3,895
11-11-2022, 06:59 AM
Replies 46
Views 7,910
19-10-2022, 08:00 AM
Replies 53
Views 7,766
18-10-2022, 06:53 AM
