Pages (51): Previous 142 43 44 45 4651 Next
04-07-2020, 12:34 PM
Do you remember how long it took me to actually place an order with them?! I was trying for months!!
04-07-2020, 12:34 PM #431
04-07-2020, 10:55 PM
I am still waiting on their response to which Speedo converter to use - I have gone elsewhere.
04-07-2020, 10:55 PM #432
05-07-2020, 01:18 AM
Must admit the bad I've heard about Thor far outweighs the good.
05-07-2020, 01:18 AM #433
05-07-2020, 01:33 AM
Sparkystav Must admit the bad I've heard about Thor far outweighs the good.
Me too mate.
Sent from my Nexus 4 using Tapatalk 2
05-07-2020, 01:33 AM #434
Me too mate.
Fozzy
05-07-2020, 10:27 AM
toxo [Image: IMG_20130808_182230.jpg]
if I were you I'd mix up some epoxy resin or araldite around the edges of this, don't want it dropping into the bell housing and melting onto the clutch plate
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
05-07-2020, 10:27 AM #435
toy215
06-07-2020, 01:29 AM
Not all front pulleys are the same dia on the various iterations of the Lexus/Toyota V8, when I designed the tensioner system you bought from thor it was for the most readily available engine...LS400... it would appear that when you changed the front pulley you used the smaller dia sc400 part hence the belt that they supplied being too long. Hope this helps you.
Roger Smith http://sjperformanceengineering.co.uk
toy215
06-07-2020, 01:29 AM #436
06-07-2020, 01:42 AM
That's a good point Roger, but I don't believe the pulleys differ in size enough to take up that slack! I'll try it out when I get back to the workshop, as I still have the old pulley.
06-07-2020, 01:42 AM #437
10-07-2020, 11:54 PM
More engine mounting fun yesterday.
These are the mods I've made to the subframe. As previously mentioned I'd cut the box towers off, I've also found that the soarer oil pan is not perfectly central on the engine - the upper sump is not symmetrical as it has the dipstick hole and the oil level sensor hole on one side, so that side is slightly larger.
As a result the oil pan doesn't quite sit in the hole in the middle of the subframe. So I trimmed one of the bars back about 10mm (marked in red) and now it sits in there lovely:
[Image: subframeMods.jpg]
I will add some gusseting between the 2 bars as this one is now significantly weaker. This has now dropped the engine right down, to nearly the perfect level, but it's still inclined upwards by about 7 degrees. I'd like it to be as level as possible...
Next problem is the rubber doughnut bit of the engine mount on the driver's side.
[Image: IMG_20130808_192927.jpg]
You can see that with the box mount gone from the subframe, there isn't enough space in there for the doughnut to miss the steering UJ. I need to come up with something much thinner! TBH I am thinking about solid mounting the engine, it's soooo smooth I don't think it needs that much isolation!
10-07-2020, 11:54 PM #438
15-07-2020, 01:12 PM
Did some more on the RX7 today. Binned off all the hydraulics (including all the ABS gumph) so that I could fit the heads on the test engine without it hitting anything.
[Image: IMG_20130826_203038.jpg]
[Image: IMG_20130826_202905.jpg]
I then hacked the rear bin kit apart so the battery fits nicely and test fitted that too. Took a while to get it spot on and had to be really careful not to scratch it at all.
[Image: IMG_20130826_203007.jpg]
The battery doesn't quite sit where I wanted but I've got access to the terminals and it's the only flat bit of the floor. Obviously I need to strap it down still but it's as good as it's going to get.
[Image: IMG_20130826_203013.jpg]
15-07-2020, 01:12 PM #439
15-07-2020, 01:32 PM
Nice mate! You decided what your doing with the pedals?
15-07-2020, 01:32 PM #440
Views 1,844
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 1,444
10-09-2023, 10:23 PM
Last Post by Jimbob-T-Lex
Views 722
21-05-2023, 10:36 PM
Replies 362
Views 31,872
06-08-2022, 09:01 AM
Last Post by john wan
Replies 1,318
Views 95,986
05-06-2022, 08:23 AM
Last Post by sarah0
Views 2,805
03-03-2022, 09:52 AM
Views 1,811
16-11-2021, 12:10 PM
Views 3,887
11-11-2021, 01:10 AM
Replies 46
Views 7,895
19-10-2021, 02:11 AM
Replies 53
Views 7,745
18-10-2021, 01:04 AM
