Pages (51): Previous 146 47 48 49 50 51 Next
12-08-2020, 12:42 PM
Trimmed that mess down to this!
[Image: IMG_20130923_203949.jpg]
12-08-2020, 12:42 PM #471
12-08-2020, 01:19 PM
Amazing how much isn't needed lol
12-08-2020, 01:19 PM #472
12-08-2020, 01:38 PM
Makes you realise how much extra stuff Lexus put in their cars though, even 15 years ago.
12-08-2020, 01:38 PM #473
14-08-2020, 12:55 PM
So, wiring
[Image: mMEh91NqKtLzE6iErSFqdcfQn7mbKbLbjSo1mo3K...eEGRp79sLE]
The ECU has 6 plugs on it, A-F. The engine has its own separate wiring loom, which plugs in to A-C. Then the other things on the engine that need switched power (starter motor, injectors and ignition coils and so on) go through connector IG1. So the separate ECU loom has these 4 connectors on it which I have not mucked about with. It's all as stock.
D-F and the other half of IG1 are on the main car loom. They go off to things the ECU needs that aren't in the engine bay. These are the fuel pump, anti-theft transponder, instrument cluster, OBD2 port, and anything fusebox/relay related. Because I broke the car I have all the connectors and wires. If you were to buy a crate engine or one from a breakers it would be unlikely you would get any of this.
This is the wiring as far as I can work it out from the wiring diagrams I got from mattlaw:
D1
D2 R (R-B) as below NOT NEEDED
D3 2 (G-B) From transmission switch NOT NEEDED
D4 3 (G) as above NOT NEEDED
D5 TC (LG-B) Other data pair for OBD2 with SIL
D6 STP (L-B) Brake switch NOT NEEDED
D7 HTR2 (GR) Heated O2 sensor B2S2
D8 HTL2 ® Heated O2 sensor B1S2
D9
D10
D11 PWR (GR-L) Power Button on gear selector GROUND THIS
D12
D13 ACMG (W) aircon magnetic clutch NOT NEEDED
D14
D15 P (L-R) PARK NOT NEEDED
D16 TACH (B-Y) tacho/rev signal, goes to instrument cluster & OBD
D17 STA (B) Starter signal
D18 OXL2 (G Shielded) Heated O2 sensor B1S2
D19 OCR1 (L-w) VVTI oil valve RH (via IG1)
D20 N (G-R) From transmission switch NOT NEEDED
D21 RSPD (V) From shift lock ECU (Road speed?) NOT NEEDED
D22
D23 CCS (V-R) Cruise Control Switch NOT NEEDED
D24
D25 MDL (Y-R) Oil Level Sensor
D26
D27 OXR2 (Y Shielded Heated O2 sensor B2S2)
D28 OCR1 (L) VVTI oil valve RH (via IG1)
11 wires needed!
E1 BATT (B-Y) from 20A EFI-1 fuse
E2
E3 SNW (L-R) ground to enable snow mode NOT NEEDED
E4 FPR (G-R) enables high-current fuel pump relay NOT NEEDED
E5 FC (G-B) grounds coil in COR relay
E6 W (Y-R) +12v from 10A GAUGE fuse via EML
E7 +BM (W-L) +12v from 15A ETCS fuse
E8 +B1 (W) from EFI relay
E9 IGSW (B-O) from 10A IGN fuse
E10 MREL (LG) outputs +12v to switch on EFI relay
E11 SIL (L) data for OBD2 connector
E12
E13 TRC+ (L) to ABS/VSC ECU NOT NEEDED
E14 ENG+ (BR) from ABS/VSC ECU NOT NEEDED
E15 KD (V-Y) to kickdown switch NOT NEEDED
E16 +B (W) from EFI relay
E17
E18
E19
E20 TRC- (P) to ABS/VSC ECU NOT NEEDED
E21 ENG- (Y) from ABS/VSC ECU NOT NEEDED
E22 NEO (O) from ABS/VSC ECU NOT NEEDED
9 wires needed!
F1 D (G-Y) from gear selector NOT NEEDED
F2
F3 IMLD (V-R) from body ECU NOT NEEDED
F4 EOM (W-B) ground
F5
F6
F7
F8
F9
F10
F11 MPX1 (??) Multiplex comms NOT NEEDED
F12
F13
F14 ST1- (B-Y) Stop switch NOT NEEDED
F15
F16 L (Y-B) from gear selector NOT NEEDED
F17 TXCT ® ignition transponder
F18 CODE (R-W) ignition transponder
F19 RXCK (R-B) ignition transponder
F20 KSW (O) To unlock warning switch NOT NEEDED
F21 LCK1 (W-G) To AC magnetic clutch NOT NEEDED
F22 ???!!!
F23 (L-P)??!!
F24 MPX2 (??) Multiplex comms NOT NEEDED
F25 4 (L-Y) from gear selector NOT NEEDED
F26 RL (Y) alternator exciter wire
5 wires needed!
IG1 connector
1 Thick B wire goes from switch side of starter relay to starter
2 Thin B wire goes FROM NSW to STA and coil side of starter relay
3 G wire from D4 on ECU, gearbox 3 NOT NEEDED
4 R-B wire from D2 on ECU, gearbox R NOT NEEDED
6 B-W wire goes FROM starter fuse TO NSW
7 Y wire goes from gauge fuse to gearbox NOT NEEDED
8 L-R wire from D15 on ECU, gearbox P NOT NEEDED
9 G-R wire from D20 on ECU, gearbox N NOT NEEDED
10 G-Y wire from F1 on ECU, gearbox D NOT NEEDED
11 G-B wire from D3 on ECU, gearbox 2 NOT NEEDED
12 L-W wire goes from ECU to RH vvti valve
16 LG-B wire is TC goes from ECU to check connector in engine bay and OBD2 port
20 W wire is from EFI #2 fuse to sensors
21 L wire goes to ECU from RH vvti valve
22 W-B wire is a ground wire to the block for the rear O2 sensors. It's E1 so also the RX7 cluster could ground here
26 B-R wire is igniter & injector power from IG2 (got power during starting)
I have a few question marks but it's mostly there Big Grin
14-08-2020, 12:55 PM #474
So, wiring
D1
D9
D10
D12
D14
D22
D24
D26
11 wires needed!
E2
E12
E17
E18
E19
9 wires needed!
F2
F4 EOM (W-B) ground
F5
F6
F7
F8
F9
F10
F12
F13
F15
F22 ???!!!
F23 (L-P)??!!
5 wires needed!
IG1 connector
14-08-2020, 01:32 PM
Lol not a lot needed then!
I'd have it all as an excel spreadsheet lol
14-08-2020, 01:32 PM #475
27-08-2020, 04:55 AM
Not much going on right now as have got a new cat so it needs a few days of house training and settling down and that kind of shite
Bought a new fuelpump, went for an Aeromotive 340 in-tank pump. Same form factor as the stock pump or a Walbro 255 but way higher flow capabilities and I bought it from Aeromotive so it's guaranteed not to be a Chinese knock off!!
Also got a tenners worth of bits from Toyota to bring my alternator and power steering pump up to scratch as well (replacing O-rings, broken plastic clips, insulators etc).
27-08-2020, 04:55 AM #476
28-08-2020, 06:05 AM
That was quick... only ordered it lunchtime yesterday!
[Image: IMG_20131009_141536.jpg]
28-08-2020, 06:05 AM #477
28-08-2020, 06:32 AM
does look like a fisher price toy in red lol
28-08-2020, 06:32 AM #478
05-09-2020, 12:14 AM
Done a few bits and bobs over the last week or two but not got any photos.
Cleaned up, stripped and replaced any broken bits on the alternator and power steering pump (1 o-ring on the PS and 1 rubber isolator and plastic insulator on the alternator)
Sprayed the alternator and PS pulleys black as they looked minging
Sanded down and sprayed the plate on the top of the PS pump black as it was corroded to hell (only part of the pump that's steel)
Started wiring the ECU up. Got an engine warning light and a circuit opening relay wired in so far. Think I might have fried something though, I wired up an earth on the ECU having counted the pins from the wrong end and it went fizz!! From where it is I think it's probably an injector driver :/
05-09-2020, 12:14 AM #479
05-09-2020, 07:17 AM
Oops!
05-09-2020, 07:17 AM #480
Oops!
Views 1,843
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 1,443
10-09-2023, 10:23 PM
Last Post by Jimbob-T-Lex
Views 721
21-05-2023, 10:36 PM
Replies 362
Views 31,871
06-08-2022, 09:01 AM
Last Post by john wan
Replies 1,318
Views 95,964
05-06-2022, 08:23 AM
Last Post by sarah0
Views 2,794
03-03-2022, 09:52 AM
Views 1,810
16-11-2021, 12:10 PM
Views 3,887
11-11-2021, 01:10 AM
Replies 46
Views 7,894
19-10-2021, 02:11 AM
Replies 53
Views 7,739
18-10-2021, 01:04 AM
