JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Lexus IS200 Amp Bypass Cable fitting with pic's?
Pages (9): Previous 13 4 5 6 79 Next
himatamba
15-06-2018, 11:30 AM
#41
did everything what u said followed the pics but my aftermakit headunit still won't turn on????help plz
himatamba
15-06-2018, 11:30 AM #41
15-06-2018, 11:56 AM
#42
Get us a pic of your ground mate.
15-06-2018, 11:56 AM #42
Ace_
06-03-2019, 10:37 AM
#43
Sorry for the ancient thread revival, but i have a few questions.
If i fit a double din unit, can i not just get a converted connector for the plug that goes into the back of the factory unit ? what is the need for this amp bypass ?
I have no sat-nav and no immediate plans to fit any further speakers etc.
Just a little confused at the need to do this.
cheers.
Ace_
06-03-2019, 10:37 AM #43
cheers.
06-03-2019, 11:48 AM
#44
The problem is, the connector behind the factory unit ONLY connects to an amp. There are no wires behind the stock head unit that connect directly to the speakers. So you have to take the amp out of the equation, and run a cable from the amp to your new stereo, which is what the amp bypass lead is!
Edited 16-04-2012, 09:24 PM by toxo.
06-03-2019, 11:48 AM #44
06-03-2019, 12:20 PM
#45
toxo The problem is, the connector behind the factory unit ONLY connects to an amp. There are no wires behind the stock head unit that connect directly to the speakers. So you have to take the amp out of the equation, and run a cable from the amp to your new stereo, which is what the amp bypass lead is!
To clarify, you take the cable out of the amp input, connect to one end of the amp bypass lead, and the other to the connector block on the new stereo, effectively taking the amp out of the setup... :biggrin:
06-03-2019, 12:20 PM #45
Ace_
06-03-2019, 01:41 PM
#46
Ahh, that explains it, iv been reading these tutorials and guides etc etc, but no one ever actually says why it needs to be done. Much appreciated! (only been hear a day and learning lots already!)
Ace_
06-03-2019, 01:41 PM #46
shuggy81
11-03-2019, 08:27 AM
#47
Hi Guys,
Firstly can I start off with saying fantastic tutorial there, it helped me alot. Although I did get a few scrapes getting that ****** amp out!!
Anyways slight problem. I have removed the amp completely for the time being. The big block connector fits into one end of the Autoleads Bypass lead I bought off Fleabay. The other end fits into the iso connecter of the cable supplied with the Pioneer 8400bt unit and into the HU. The issue here is that i get no power going into the HU, any reason why ?
Incase I thought I blew a fuse, i connected the old stock HU and that powered up fine, so i'm a little confused.
Any help would be much appreciated.
Thanks
shuggy81
11-03-2019, 08:27 AM #47
Hi Guys,
Thanks
speedfreek
11-03-2019, 08:40 AM
#48
From memory, I had to swap over a couple of wires (red and yellow) to make mine work.
But yeah the amp is in a bloomin awkward place!
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
11-03-2019, 08:40 AM #48
[/SIZE]
(Current project)
11-03-2019, 10:03 AM
#49
If its anything like the lead andymunro and I fitted today then it's a shocking example of a lead!
Do you have a pic of it?
The one we had only had one power wire, and both rear speakers wired to the left rear. Also the mute wire grounded?
11-03-2019, 10:03 AM #49
shuggy81
11-03-2019, 02:49 PM
#50
Hi,
I'll take some pictures of it tomorrow, get some closeup shots.
It's the Autoleads brand that was sent, and was bought from this guy, and its the same lead in the auction
http://www.ebay.co.uk/itm/LEXUS-IS200-01...5645f5d15f
I would have liked it being "plug n play" but it's never that easy is it!
shuggy81
11-03-2019, 02:49 PM #50
Hi,
Views 662
30-09-2022, 11:42 AM
Views 7,551
18-10-2021, 01:12 AM
Views 683
02-12-2020, 01:19 PM
Views 797
31-03-2020, 12:49 PM
Views 582
26-01-2020, 01:12 AM
Last Post by Colin G
Replies 22
Views 1,533
05-10-2019, 03:45 AM
Last Post by Predator
Views 2,426
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 715
28-09-2019, 08:22 AM
