JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza BOOT Control
BOOT Control
BOOT Control
Pages (5): Previous 1 2 3 4 5
21-06-2018, 07:14 AM
#41
parthiban I wonder if someone could find the mechanism on an SC430 at a breakers and fit it to an IS200 to make the boot open and close remotely......where's Rabs, sounds like a job for him Smile
The boot only closes remotely when the roof in operation.
I guess the motors needed would cost too much even if you could get it to work plus there are so few SC430 out there to get all the parts required.
21-06-2018, 07:14 AM #41
Fozzy
21-06-2018, 07:24 AM
#42
i could make a kit that would do it, its very simple, just using a hydraulic pump and a couple of actuators, like you would find on the roof of a small convertible. Problem is it will take up a bit of space, but it would be quite trick. You just put the hydralic actuators where you would have the strut. Its a simple system, put fluid in one end of the actuator and the boot opens. Switch a valve and pump fluid in the other end and the boot closes
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
21-06-2018, 07:24 AM #42
21-06-2018, 07:38 AM
#43
Hurricane i could make a kit that would do it, its very simple, just using a hydraulic pump and a couple of actuators, like you would find on the roof of a small convertible. Problem is it will take up a bit of space, but it would be quite trick. You just put the hydralic actuators where you would have the strut. Its a simple system, put fluid in one end of the actuator and the boot opens. Switch a valve and pump fluid in the other end and the boot closes
Ahh so not that expensive to do? Didn't think it would be that complicated, but thought it would cost a lot due to the parts involved, but if not that would be brilliant. I'd love this if it could be done Smile
21-06-2018, 07:38 AM #43
Fozzy
21-06-2018, 08:23 AM
#44
I might have a word with Rabster and see if we can come up with something. It will be a bit of a winter project, but i dont see it being difficult to do at all
Fozzy
21-06-2018, 08:23 AM #44
Views 495
28-03-2023, 05:05 AM
Views 1,552
22-07-2022, 05:42 AM
Views 266
23-03-2021, 05:40 PM
Views 1,124
02-09-2019, 06:19 PM
Last Post by dodgydave
Views 735
23-05-2019, 03:58 PM
Last Post by Dinho
Views 917
01-04-2019, 04:21 PM
Last Post by jasons
Views 1,329
13-01-2019, 10:06 PM
Last Post by hawk77ojc
Views 992
04-11-2018, 04:05 AM
