supercharged is200 you might want to look at this
Buy one of Patriks instead
Sparkystav The BCC is almost exactly like the orignal black box that clamps the voltage once it goes over a set figure, rather than the FCD that "lies" to the ecu right through the range when its not needed, only once the MAP pressure gets towards the boost cut.
Your exactly right mate its 4.34v but you can set it at 4.34 as thats what the black box is.
lol fair enough.
not sure what the actually cut level is to be honest, just know the black box is set to 4.34, so the cut could be higher.
I noticed this a long time ago too, but when I needed one I couldn't find one anywhere, and I looked in the UK, US and Japan! So bought a used black box (from you Stav, I think? Long time ago!) As Patrick is now making some black boxes, I would have thought that the ideal solution? FCDs are very easy to come by, probably why they are so commonly used, even though not ideal.
I am reconditioning my charger as I don't think it's been done since it was originally fitted, and has not been used in a while. Plus I have it off one car for a couple of weeks before fitting it to another, so why not?
That's it Ormi you've got the old cogs turning now.
I've got hold of a second charger unit and it's a brilliant one. Once i cleaned all the gunk out of it i noticed it's in really good condition inside, hardly any scoring at all. Much better than my current one. :biggrin:
How much is it costing you to get your pulley machined?
If the price is right i wouldn't mind sending mine along if you'd kindly pass on the details.
I might be way off the mark, but i think i smell a group buy. :thumbup1:
Talisker That's it Ormi you've got the old cogs turning now.
wow seems like a good idea getin the most out of the charger, i noticed a few of you have got a second m62 charger to mess about with, if ormi gets it all done and it works better i might try and get something done like this but where sould i look to get a second m62? not much on ebay that ive seen and not sure where else to look internet searches bring up alot of out of date threads.
