JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Heater control led guide
Pages (8): Previous 14 5 6 7 8 Next
reco2k
22-03-2019, 11:34 PM
#51
Im working on the dash as we speak, its a lot harder than the heater controls but almost done :-)
Ross
reco2k
22-03-2019, 11:34 PM #51
Ross
23-03-2019, 01:53 AM
#52
I'm just going to go and get some superbright SMD's this time, only got 3cell 3030 T10's in there at the moment, I reckon 7 SMD 5050 T10's would generate a much nicer finish.
Looking good though.
23-03-2019, 01:53 AM #52
reco2k
24-03-2019, 01:00 AM
#53
Sorted my speedo at last, just need to wore it into the dimmer switch as it is a little bright but light spread is good
[Image: d924daec-a28c-08e6.jpg]
[Image: d924daec-a297-eb07.jpg]
Ross
reco2k
24-03-2019, 01:00 AM #53
Ross
24-03-2019, 01:07 AM
#54
jesus christ, you have las vegas behind your steering wheel.
Looks brilliant mate!
24-03-2019, 01:07 AM #54
24-03-2019, 04:14 AM
#55
Also - you might have to mess about with the dimmer switch, as mine doesn't work at all with SMD's installed.
24-03-2019, 04:14 AM #55
reco2k
24-03-2019, 06:22 AM
#56
Yeah im going to test the voltage and see how much it changes, might just run a new lower voltage supply to dim it down a bit
Ross
reco2k
24-03-2019, 06:22 AM #56
Ross
24-03-2019, 06:41 AM
#57
I wonder if you could mod the switch to run 3v, 6v, 9v, 12v. I think it might be passing too much current through all of the modes at the moment, as it literally does nothing for the SMD lamps.
24-03-2019, 06:41 AM #57
jomo
24-03-2019, 08:01 AM
#58
el_bandido Also - you might have to mess about with the dimmer switch, as mine doesn't work at all with SMD's installed.
Dont have a prob with my dimmer switch and SMD's?
jomo
24-03-2019, 08:01 AM #58
24-03-2019, 08:26 AM
#59
mine worked fine with incandescent bulbs but doesn't dim the SMD's at all. Mine is a 2000 plate though.
24-03-2019, 08:26 AM #59
24-03-2019, 08:40 AM
#60
jomo Dont have a prob with my dimmer switch and SMD's?
Mine is fine too Smile
24-03-2019, 08:40 AM #60
Views 569
12-03-2021, 11:09 AM
Views 676
25-07-2019, 11:59 AM
Last Post by lex2oos
Views 636
18-05-2018, 01:25 PM
