JapCarForum Cars, Cars, Cars! Project Cars My Subaru WRX
My Subaru WRX
My Subaru WRX
Pages (19): Previous 16 7 8 9 1019 Next
24-12-2016, 02:09 PM
#71
looking very nice mate
24-12-2016, 02:09 PM #71
rig-pig
25-12-2016, 01:03 AM
#72
looking good m8, i was looking into de-cat/sports cat for the down pipe but when speaking to Subaru tuners up my way they said that unless you are doing a lot of track days or driving flat out everywhere then its not worth changing the down pipe to a sports cat/de-cat you are better to change the up pipe(pre-cat before turbo) de-cat the 2nd cat and change the mid section and back box
[Image: Photo003-1-1.jpg]
Craig
time served car mechanic
now a rig monkey
rig-pig
25-12-2016, 01:03 AM #72
Craig
now a rig monkey
russelllinn
25-12-2016, 09:18 AM
#73
Haven't heard that way, what I have now which I have been told is a good setup is tubular manifold with straight through up pipe, then open neck sports cat down to decat centre section through to the back box. I too wouldn't suggest de-cat all the way through now.
russelllinn
25-12-2016, 09:18 AM #73
25-12-2016, 10:06 AM
#74
russelllinn Had the lights and side markers painted what do you think, i'll get a couple of more pics when its sunny again (fingers crossed)
[Image: Photo1011.jpg]
Thats so much better:thumbup:
25-12-2016, 10:06 AM #74
russelllinn
25-12-2016, 10:11 AM
#75
Thanks guys always nice to have approvals of things done Smile
See what you can get Dean :wink:
russelllinn
25-12-2016, 10:11 AM #75
rig-pig
25-12-2016, 12:45 PM
#76
yes m8 that's the best set up for track days and fast road who are you going to get to MAP/ECU it after the exhaust is changed
Craig
now a rig monkey
rig-pig
25-12-2016, 12:45 PM #76
Craig
now a rig monkey
russelllinn
25-12-2016, 02:58 PM
#77
I am gonna use Dave Row from EPS, the Subaru garages use him down here and so does RCM so he is good :thumbup1:
russelllinn
25-12-2016, 02:58 PM #77
25-12-2016, 03:46 PM
#78
That's looks a lot tidier mate, makes the front end look so much better :thumbup:
25-12-2016, 03:46 PM #78
russelllinn
04-01-2017, 02:53 AM
#79
Well not everything can go to plan I guess as day before yesterday I went out in car in the evening and as I drove onto the main road to accelerate I decided that they're could be an issue as unless someone had swapped my engine over for a diesel I was sounding like a tractor Confusedad:
I have tubular headers although not sure where from as they were on the car so probably not the best ones!!
It was too late to get to a garage to have a look underneath but I could feel the exhaust gases under the front off side, too close to be a gasket I thought, had it up on ramps today and it has cracked where the four tubes go into one to go to the up pipe, they tried welding it but could not get above it and so it is better but not fixed, looks like its new headers then which is a bit of a pain.
Having spoken to the garage that’s doing my upgrade I will probably be getting the Roger Clark (RCM) ones but at £460 (discounted!!) they're not cheap but as always come highly recommended!!
In the meantime, to cheer myself up :laugh: I have ordered an anti-lift kit http://www.cdfracing.co.uk/product_info....c22c9e99d6 and up rated drop links http://www.cdfracing.co.uk/product_info....c22c9e99d6 for when I have decided on which ARB's to get, any suggestions welcome, currently thinking Eibach or Whiteline
russelllinn
04-01-2017, 02:53 AM #79
04-01-2017, 04:01 AM
#80
That's a ****** Sad but is a fact of life with tubular manifolds on high performance engines unfortunately.
Your other option I guess would be to get some bracing made up so that there's less force transmitted through the welds. I ripped an exhaust flexi once from the movement of my engine which would've killed a stainless mani if I'd had one. Weakest part of the chain and all that, especially when they've got the weight of a turbo on them.
Whiteline ARBs get a really good writeup on the MR2. Are they adjustable on the Impreza?
04-01-2017, 04:01 AM #80
 8 Guest(s)
 8 Guest(s)
Replies 57
Views 3,731
16-02-2024, 09:45 PM
Views 1,162
05-01-2023, 01:56 PM
Last Post by Jimbob-T-Lex
Views 2,130
20-06-2021, 04:50 AM
Views 1,097
21-02-2020, 12:58 PM
Last Post by jura
Views 2,782
19-05-2019, 07:53 AM
Last Post by Shaun TDI
Replies 22
Views 2,003
30-09-2018, 05:11 AM
Last Post by scooby 887
